  • Guests: 16
a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
05/09 Coronafix (51)
Chemcial testing
Andy
Wed Feb 19 2014, 07:47AM Print
Hi
I'm thinking about selling chemicals to another supplier, and they are asking for chemical tests to be done.
I was wondering what that involves and what company in NZ would do that.
Any extra info welcomed.
Thanks
Andy
Shrad
Wed Feb 19 2014, 07:58AM
purity, reactivity, curves, titration, etc...
Andy
Wed Feb 19 2014, 08:30AM
Hi Shrad
The chemical is acetone, Who would do those type of tests, do they do it every month on a random batch/once a year, do they look at the system. I've got to find out from the supplier what they will find acceptable, to get 100% purity I will have to use copper sulphate to remove water which will leave traces, would that be a problem. How much do you think they will charge. What amount to they test, 10ml,200L. Do they test the steel drums, what cert do I need for them, is that apart of the tests.
The supplier just is asking for a testing document, could you add to the "etc"
Thanks
Wed Feb 19 2014, 11:58AM
I imagine that your first concern would be safety,
regulations regarding storing and processing
significant quantities of a very volatile flammable liquid.
Maybe your local fire, police and civil authority need to know / give approval ?
Regarding testing,that would depend upon your clients requirements,
pharmaceutical and industrial grade for example.
Andy
Wed Feb 19 2014, 05:30PM
Hi Sulaiman
It will be industrial grade. Regarding storage, it has to be in a brick building with the approate signage. The processing looking at Link2 it should be ok. I will be ringing the local council for permits etc, but I'm more worried about the testing, as it could make or break the idea.
2Spoons
Wed Feb 19 2014, 09:23PM
Why ask here when googling "chemical test lab nz" provides half a dozen leads. Get on the phone - if they can't help you you can bet they will tell you who can.
Wed Feb 19 2014, 10:34PM
P.S. acetone is a pre-cursor for methamphetamine and as such may be subject to special regulations/tracking etc.
Be sure who your clients are !
Andy
Wed Feb 19 2014, 11:07PM
Thanks Sulaiman, I'm trying to only deal with major suppliers.
2Spoons, I have rung up some of them, but they would like to know what test I want done. I can get that off the client, I was just trying to fast track the thing.
Shrad
Thu Feb 20 2014, 09:01AM
don't your brick buildings have to be ATEX to hold volatile and explosive products? (ie special compliant electrical installation, no phones or RF devices, etc...)
Bored Chemist
Thu Feb 20 2014, 08:29PM
Shrad wrote ...
If I go to a hardware store where you are, do they sell methylated spirit (denatured alcohol)
Do they take my 'phone off me before I go in?
