Tritium lights!
EEYORE
Fri Nov 15 2013, 06:56PM
Registered Member #99
Tritium cast in Resin I have two tritium casts made with resin. Each was going to be a keychain but I decided to leave them as is. Both have dual 22mm by 3mm tritium vials. One is green, the other blue.
The green is made with crystal clear resin. The blue is made with a hazy type for a diffuse look. Both are bright!
I can drill a hole and polish it if you would like to use a key ring with it.
I'm asking $55 each shipped in USA, or $95 for the pair.
EEYORE
Pics...
