Registered Member #1749
Well as soon as I can get a new camera because my old one pooped out I can show you guys the effect on a little fly back transformer and a copper foil Primary only 5 Turns driven by a TL494 with audio modulation on 12V the arc is a little over 1 1/2" and is so hot it turns the ground pin red instantly it is actually an improvement over my best ZVS Driver at the same voltage and the audio is very loud. I have noticed the IRF510 is no match it latches up fast so I found a CEP50N06 a nice little 50V@60A Mosfet that is much better and last for several minutes before my heat sink is to hot to touch any advice on improving the switching on a TL494 circuit.
My transformer design will defiantly have a wide copper foil Primary when I can get the time to buy the needed material to build it.
Here is the video of the transformer with the copper foil primary but the CEP50N06 burned up so now I am using a BUZ11 mosfet it works ok but not as good Sorry about all of the noise in the back ground and the bad video I used my android phone I did not run audio through the driver for the video.
And with the BUZ11 the arc is not as hot as it was with the better mosfet.
I am considering a differnt aproach to the primary winding on a new flyback design me and allot of others have made external primarys for ZVS and other drivers I am going to design my flyback with a Robust copper foil internal primary instead the out put on my flyback was minimal compared to the internal primary. Check out this video of the same transformer as the last one but using the internal primary VS the external one I made.
Here is another design I made up in a few hours I thought it would be neat to incorporate an oil cooling system with a PC water cooler radiator and a small oil pump and have the ability to change the HV wire so after it gets cooked it can be replaced.
Registered Member #3324
Very nice looking!
thing is, anyone can wind a transformer and make a good one at that with some practice... the real problem and issue comes with trying to find a ferrite core sutiable!
Registered Member #162
If I was to make a similar hv transformer I would; - have two similar sets of windings, primary next to core, secondary on top of primary . bring out and terminate all four windings, allowing for series/parallel primary/secondary
this way you can have flexibility; . series/parallel primaries for high/low voltage drive . series/parallel secondaries for high (balanced) or low voltage, low/high current.
5-0-5 kV is easier to insulate than 0-10 kV and can power a better 'C-W' multiplier.
I wish I could figure out how to make transformer windings with solid works it would look allot better. And once again wish I could make the core. Sulaiman great idea maybe take the first transformer design only with 3 or 4 Secondaries in stead of 7 and collaborate the second design with a better look and with all of the cooling it could be a very reliable transformer. I am also considering a Low voltage ultra high current Design I am considering oil cooling and core cooling any thoughts?
And this seems like a good way to make molds for acrylic.
Registered Member #3414
I think your cooling system above misses the point. If you are pushing the ferrite to the limits it will get very hot, and require cooling. You need to submerse the whole Xformer under oil. By all means use directed forced oil cooling in the places that require the most cooling, but you need to cool the whole Xformer.
Good point I will reconsider My design maybe an oil cooling sleeve around the ferrite or incorporate channels with in the core for oil flow Most of my design is to look good and also minimize Size and weight while Keeping the ability for several KV and or Current. I want to keep the large oil tank out of the picture with a small Reservoir, A radiator and an oil pump as well maybe oil cooling incorporated to the Semiconductors Heat sink.
Well for making cores I would choose Manganese-zinc ferrite because I don't think we would ever need anything going above 1-200KHz. You can get 10 pounds of Manganese powder for $20 and 5 pounds of Zinc Powder for $30 and not to forget 5 lb of Synthetic Black Iron Oxide for $24 Finding the right formula for these powders is key MnaZn(1-a)Fe2O4.
I read somewhere recently that you first sinter the 'ferrite', then grind it into a powder with a particle size of ~1 micron, then re-sinter.
I also read that, sometimes at micro-metals, they would need to adfjust the ratios to obtain specified tolerances, but sometimes they could just increase the pressure by 'several tonnes' to get a denser product that met the spec. I understand they are pressed, then fired.
I also read that you 'may' be able to 'fire' them in a microwave oven.
What are you going to use to press the cores before firing?
EDIT: By the way, this is as far as my design has got:
The core has a CSA of 18cm^2, but I'm considering doubling up on the amount of ferrite, to 36cm^2, which will allow me to half the number of turns. See thread here:
