  • Guests: 21
Linas (34)
Toasty (29)
05/16 kg7bz (68)
05/16 steve516 (31)
05/17 Finn Hammer (72)
If you where able to make your own Transformer what would it look like?
1 2 3 4  last
Chris Cristini
Fri Aug 30 2013, 02:53PM Print
This is one of my ideas it is a High voltage fly back with 7 primary's I am still in the process of learning how to form my own High frequency Ferrite any ideas?
8 Zps42ad7bc5
7 Zpsc3c3d40a
1 Zps69213da9
5 Zps1932c769
6 Zps07616387
Or maybe get some cores and grind them?
Tetris
Fri Aug 30 2013, 07:30PM
I'd probably make one look like something out of Frankenstein... like... a modified Tesla Coil - Jacobs Ladder combination or something.
Experimentonomen
Fri Aug 30 2013, 08:01PM
Why 7 primaries ?
Ash Small
Fri Aug 30 2013, 09:21PM
Just use seven (or whatever) flyback cores, or other ferrite cores, you should still have plenty of room for the secondary (or secondaries).
Chris Cristini
Fri Aug 30 2013, 10:03PM
Sorry I meant 7 secondary's for a series output and yea I was thinking of simply making it out of 7 pre made cores but how cool would it be if you could make your own cores. I was considering getting some pottery clay and mixing it with pure iron powder and making a mold to put it in an oven.
Do you think this Link2 would work good with some pottery clay?
Or maybe like this. Link2
Sat Aug 31 2013, 07:30PM
This!
1377977422 15 FT156783 Image006
Sat Aug 31 2013, 08:20PM
Where can i get that?
Chris Cristini
Sat Aug 31 2013, 09:20PM
WOW Impressive wonder what that is used for.
I think I have seen that picture before but did not know the voltage or the VA.
Can not believe there is a desk next to it.
I want to build the core I presented with a 12" radius I think it would have great potential at that size.
Here is another way to do it. Link2
Sun Sept 01 2013, 11:57AM
Ideally i would like somthing like your transformer Chris, the problem is,
i need to find the ferrite..... im trying to build a 10-13Kw Ferrite transformer
to go with the lovely Fullbridge of CM600 Equivilents... problem is its only at 20Khz....
Chris Cristini
Sun Sept 01 2013, 02:45PM
Well I came up with an other idea would a ferrite E core as big as a micro wave transformer work better.
Also if I create a transformer that works from my own iron powder mix. Would that be a good subject for the HV Wiki how to make your own transformer core? Or would that be something to sell custom cores?
1 2 3 4  last
