  • Guests: 17
Steve Conner (46)
04/29 GODSFUSION (37)
04/29 Zajcek (37)
04/29 ElectroDog (33)
End-on spark view - broken sparks
Tesladownunder
Sat Sept 02 2006, 05:51AM Print
Here are some interesting shots of sparks taken end on. I used my MO-SIDAC-ignition coil setup which gives 4 inch sparks.
With 2 fine electrodes and aligning the camera down the axis you get some unusual effects.
Peter
1157176291 10 FT0 Hvmosparksendon1
1157176291 10 FT0 Hvmosparksendon2
Part Scavenger
Sun Sept 03 2006, 01:01AM
Cool. Reminds me of medusa.
Tesladownunder
Sun Sept 03 2006, 03:04AM
I was wondering about the discontinuity of the sparks with apparent gaps. Others have observed this and commented on it in Tesla shots.
I offer this explanation. An area of hot gas will act as a lens (concave type) due to the central rarefied area being of lower refractive index. This will act in mirage like fashion to diffuse the spark area beind it so that you get to see only a fraction of what you might otherwise.
This effect will be seen more on longitudinal shots which is exactly what you are seeing here and much more than in the standard right angle view.
The second pic shows the faint connecting segment. So this is the real black plasma tongue
Any comments? I haven't seen this lensing effect given before.
Peter
1157252650 10 FT15549 Hvmosparksendonsegment2
Bjørn
Sun Sept 03 2006, 12:15PM
Take two pictures at the same time from different angles.
Electroholic
Sun Sept 03 2006, 08:21PM
great idea but how?
oh heres and idea, how about a mirror?
that would give you another angle,
not exactly at the same time, but should be close enough.
Sun Sept 03 2006, 09:18PM
I think it's because of the timing of the spark interacting with the timing of the camera shutter. This can lead to some weird results in cameras with focal plane shutters (a travelling slit that doesn't expose the whole frame simultaneously) I've posted about this effect on the TCML quite a few times.
Of course, if it was a time exposure, please ignore me :P
Bjørn
Sun Sept 03 2006, 09:37PM
I was thinking of a mirror.
These pictures seems to be taken with a 2 second exposure time. The shutter may still generate some artifacts if something happens at just the right time.
Sun Sept 03 2006, 11:06PM
Definitely not the shutter. If the camera captures the arc from beginning to end, and the gap is in the middle, than it definitely isn't the shutter.
What is happening is as TDU stated. When an arc channel forms, it superheats the air leaving a nice heated air channel which rises and thus blocks light from new arcs causing them to appear "broken" and "segmented." With larger Tesla coils (bigger arcs), the effect also occurs, but since the arc length is very large and not confined to such a small area, you don't see it as readily.
With some single-shot discharge photos i've taken, i've actually captured the shadow of the channel (after the arc occurred), on the wall behind it with the flash.
Tesladownunder
Mon Sept 04 2006, 12:06AM
On further reflection, I don't think lensing is the effect since it occurs at only one point along the spark.
I now suspect that it is just a Crooke's space effect in a predominantly DC spark.
Note the brightness variation and where the dropout occurs.
Now also note the same effect with a TC. which to me implies some constant effect of polarisation of the spark. ie only positive or negative strokes make it. That is not surprising as a spark from smooth surface to point is affected by polarity by a factor of two if I recall. I did some measurements on this a couple of years ago.
Peter
1157328404 10 FT15549 Hvbrokensparksx3
1157328404 10 FT15549 Hvbrokensparksx5
1157328404 10 FT15549 Teslaphysicsrun5secs
Mon Sept 04 2006, 01:12AM
Interesting effect, although I am still not convinced its an actual effect occuring within the arc. Do you have other cameras you can use to attempt to capture this?
I've taken literally tens of thousands of high voltage images ranging from low voltage DC discharges, to spark gap coils, DRSSTCs, high power Marx Generators, to lightning, and never have seen this effect even once.
Seems weird you have caught it numerous times, and in the last three photos all to the right side of the image.
