  • Guests: 24
Colin 99 (53)
05/14 hvguy (41)
05/14 thehappyelectron (14)
05/14 Justin (2024)
Barrys RLC sim
Fri Jun 21 2013, 10:49PM Print
Hey guys,
Barrys RLC sim wont work for me because its on a older version of java and refuses to work with the newer version
is there any other sims that will work for me that i can use?
if someone else can access it, could they plug in these values and give me a pic of the graph?
4700uf 400v
49uH
0.1 Ohms
the coil is
170 turns
40mm long
1mm wire
Huge thanks,
Saz43
Fri Jun 21 2013, 11:00PM
Works fine for me. Are you making a coilgun?
1371855606 1525 FT155263 Rlc
Fri Jun 21 2013, 11:07PM
Thanks Saz!
Indeed i am, this would be my first coilgun.
I need to get a good thyristor..... damn >_<
how would this do:
2830A non repetitve Current No Voltage Reapplied
Saz43
Sat Jun 22 2013, 11:46PM
That would work great. The peak current rating in the datasheet is usually for an 8.33ms pulse (half a sine wave from 60Hz mains). Since your current pulse is only 1.7ms long, the SCR could probably withstand even more current.
Mon Jun 24 2013, 01:01AM
__=|(:3)-|--{__ wrote ...
Hey Thomas, can you tell me more about what version of Java you're using? Especially if you can send me a copy of the Java console log, that would be great. Either here or a direct email, whichever you like.
Saz43 wrote ...
Good advice. Those stud SCRs you found on eBay should work well and probably last forever with your capacitor.
Cheers, Barry
“Magnetism is one of the six fundamental forces of the universe, with the other five being Gravity, Duct Tape, Whining, Remote Control, and The Force That Pulls Dogs Toward The Groins Of Strangers.” – Dave Barry
Mon Jun 24 2013, 11:46AM
GCNDGEN
AEP7ni4
There
Mon Jun 24 2013, 03:15PM
Try upgrading your Java run-time environment (JRE) to version 7 update 25 or later. Link2
You should get an option to accept the warning and run my Java applet:
U25
Oracle messed up its recent security updates and issued several in a row. You just need to get the latest.
Cheers, Barry
I think soda cans are alive and each time you take one out of the pack and open it, you're really snapping its neck and drinking its blood in front of its family.
Mon Jun 24 2013, 08:31PM
Thanks!
