Registered Member #1938
Here is a dental x-ray head, exposing a connector with 4 pins: Measuring them led to nothing, so I had to open the case, save the nice paraffin oil, check the wires, then put everything back together.
The high voltage transformer has a 220V primary and two secondaries: a HV one and the filament secondary According to the numbering presented in the first picture, 1 & 2 is are the mains pins (220V) connected to the HV transformer primary. Pin 3 is one of the filament connections, floating above ground. Placing a resistor between pin 3 and ground will limit the current fed to the filament, and so the temperature of the filament and the intensity of the x-ray output. I have no idea what pin 4 is, but I assume it is a tap on the HV secondary used to measure the output. Something similar to this:
Everything was put back and case resoldered. Finally I applied a black paint layer, that looks good
After putting everything together and connecting the head as presented here, it appears to work, but the pin 4 arcs to ground: The bulb was added between pin 3 and ground to limit the filament current and greatly reduce the x-rays output. A sensitive geiger dosimeter (RADEX 1706) would detect the emission only when placed in front of the outputting window.
To stop the arc, as a temporary solution , I placed a HV 1K resistor from pin 4 to ground as shown in the last picture. The frontal window exposes an aluminum disc of about 0.8 mm width.
The question is: Does anyone recognize this head or has any info on what the pin 4 is?
Registered Member #56
Are you sure that the pin is not simply the return for the high voltage coil? It seems logical that they would route it through the connector so that you could put in a resistor (1k is a good value) to measure the current flowing through the tube.
It is possible . I asked hoping someone would recognize this head model. For now it works as it is, and I don;t have plans for making a fancy circuit for it, as I would only need it on rare occasions , for "debugging" black boxes.
Registered Member #33
Nice shot. Do you have some details on the type of screen and camera used, voltage, current, distance, iso and exposure time?
The circuit is most likely very similar to the attached image, minus the separate filament transformer. When x-ray tubes are used in self-rectified mode, the current sensing resistor needs to be in series with the secondary instead of between the center-tap and ground.
Hi Anders,
Judging from the internals, I'd rather go for the attached diagram . Do you feel it looks like a common topology? Also the pics show the secondary as a single block, what do you think? In my setup, Pin 3 is connected to ground for maximum filament temperature. Pin 4 is connected to ground , via a 1K resistor. Before the 1K resistor, pin4 was arcing to the case, like shown in the pictures above.
Registered Member #122
This is a really nice object!
You can use it for build a really compact machine capable of both radiograpy (powerful shots for really short times only)and radioscopy (less powerful shots, but capable of few tens of seconds exposures), you only need a proper value resistor in series of pin 3 and a switch without any external transformer or any other bulk equipment!
