  • Guests: 12
cbfull (52)
Steve Ward (39)
05/19 cbfull (52)
05/19 Steve Ward (39)
05/20 Vaxian (17)
CNC mini mill
dingo27
Mon Apr 08 2013, 08:11PM Print
dingo27 Registered Member #890 Joined: Tue Jul 10 2007, 10:06PM
Hello, i know i should not be doing this (because i still have my DRSSTC pending),
but i will try to show a progress of my CNC mill setup. Control electronics will be done with parallel port connected to few Microchips PIC processors (goal is 3 for motor and 1 for LCD Data).
Why so much? Well, when coding i really cannot drive all three motors with one uPC as good as with more of them. Simply if one motor is turning, others has to wait until subroutine ends, this way i can control all at once regardless of state of others.
So, i avoided ttl and logic components, and transformed this schematics into PIC ASM code (sorry for misleading comments, it's in my mother language)
Stepper
Trick to succesfully use RRF and RLF function is to know where CARRY bit is, and also rotating binary value of "10001000", so at first or last 4 bits, there will be one active bit. It was easy to think, but harder to use in successful program (for me)
This program will be later transformed into 8, maybe 14 pin PIC (2 extra pins for incrementing and decrementing value). Power part will contain L293D 4x half bridge (which was already successfully tested on breadboard).
Code removed due to obsolence, if you need updated one, just send me PM
Wed May 01 2013, 03:51PM
can I see pics of your quil/spindle ?
The Lightning Stalker
Sun Jun 02 2013, 08:50AM
The Lightning Stalker Registered Member #4230 Joined: Sat Nov 26 2011, 05:50AM
How are you going to interface this with the computer?
dingo27
Mon Oct 28 2013, 06:27PM
Hello, this is not dead yet, i just do not have any time in summer. So, a few updates-
1. succesfull build of stepped driver for bipolar stepper motors (it can use 4,5 or 6 wire steppers)
2. build of "embedded computer" with pic 16LF877A for this thing, to show coordinates and control gantry
Now for a few questions - i will use parallel port with optical isolation, i have some basic schematics in my mind, i also tried it with 2 pins and it did not worked out - i think reason of this is that i used mach 3 in win7 and mach3 advises to use XP or older... ( :( ) For this purpose i have one old pc in my shelf, just get that old OS somewhere...
For spindle i plan to use motor from my mini chinese dremel copy, which i hope will work for time i get most of the bugs out of that...
pic 1 - stepper driver with pic16f628a, 4 leds that indicates current step phase and L293D
DSC 0425
pic 2 - my "embedd system" which contains 20x4 LCD, pic16f877a, to right you can barely see icsp header for pickit3, one header down for keyboard (6 pin ports - PORTA), other 2 8bit ports are covered by lcd
DSC 0455
pic 3 - below is my soldering and pcb design, i think this was too small for me
DSC 0457
pic 4 - my pic16f84a testing program - i cannot use this because this doesn't have no of i/o ports i need
DSC 0427
But i need some help - i cannot get LCD of my embedded system start to work... cursor of that is blinking, also it is moving, but not a single character can be shown. could someone more skillfull help?
Code removed for space reason, looked ugly
EDIT: i think there is something about port setting, something that 16f84 does not have...
I am searching for some 877 sample codes, for now without luck but i found out some ADCON setting (which i think is analog to digital converter),
Edit2 - internal pullup setting does not work (BCF OPTION_REG,7)
also output pins are ok, i scoped nice 4ms square wave of every one on port B, so pullups are working, but whole thing is not ok. I also tested LCD and it works ok with old circuit on breadboard. I have it connected through whole port b and port e, which can be seen from code.
dingo27
Wed Nov 13 2013, 10:07PM
First - i hope you all see images above and in this post.
Well, i am still tinkering with my mini lcd thing, so while i wont solve this, i did some mechanical stuff, this was done in 2x 2 hours after work today and yesterday,
DSC 0550
This will be X axis, rails are 55cm long, but i will move only half of that length, so around 20cm of working space, and appx. same will be for Y axis. There are already two step/dir motor drivers, which i am going to modify a little (using few outputs of pic16f628a which drives them to control my LCD thingy)
I need to have my spindle closest to center of the rails as possible (to use as much of those 55cm), which means i first have to build Y and Z dollies and then center it. Dollies will use simple small bearings against those aluminum profiles. They are not exactly straight, but - oh well, this is just for testing purpose, i'll be happy if i will be at least able to control something with pc. Upper aluminum will not be like on photo, but vertical for easier dolly setup. Or maybe i will use two metal rods from some printer, i currently have my hands on.
For leadscrew, i am using M6 threaded rods, which means for 1 turn i have exactly 1mm move. for current steppers that gives me 1/48=0,021mm - but lets say 0,025mm accuracy per step.
It seems this won't be as boring winter.
Edit 10th december 2013
little cad porn, this is to help me visualize before making y axis... this could work, but most of things i made usually dont, so i hope i wont be dissapointed at the end.
Cnc
dingo27
Thu Oct 30 2014, 08:57PM
After year, things are getting a lot slower than i thought...
Upper "PIC embedded solution" will be divided into few more separate, but simpler (to program) circuits - 3 axis dimension display with 7segment LED display, and one master unit which will constantly monitor overcurrent for motors, axis limit tactile sensors, and after start will make homing and possibly control gantry with manual override, with (2x16 lcd / LED) indications of errors. My stepper driver will be modified (code + some wires on few tactical spots :) ) to obey limit sensors. (why oh why i did not add some additional input connectors on pcb... )
Here comes what i've done (in last week)
-built x axis bed - this looked pretty easy until it showed my x axis rails are bent, oh ... for now, it will do. Missing stepper motor holder (70% done)
-built y axis rails, dolly (x2), bearing holders, y axis side aluminum base, missing only holders for y axis rails (8x L shaped profiles). Pre-drilled to accept stepper motors and mate with base that holds x axis. (90% done)
Does not look that much but it was lot of drilling, filing, CADing, marking, measuring and mainly thinking about making use of materials i have limited resource of, so using as maximum possible usage of material with minimum waste is a must. Most parts are from printers, scanner and so. Those rails especially are hard to get, not even two identical ones. Eagle eyed viewer can see i won't have that much use of long x rail due to short dolly - that is right, as now i don't have any other bigger flat material to use.
Below picture of nearly finished y rail with x rail below and x + y dollies. - due to fact i have only table drill and dremel (not able to produce anything in cnc or with any high precision at all), i am quite happy with precision i can get from these tools
IMG 8314
More images here (picasaweb) Link2
-nearest things to do
1.finish y rail bed; make holder for x axis stepper motor, make base for z axis (will use 180mm long rails, i am not desided if rails should be steady or moving, will need a lot of CADing and thinking)
