  • Guests: 25
05/27 Daniel Davis (53)
05/29 Zonalklism (33)
05/29 Dr Hankenstein (67)
New HERF idea...
Slava
Wed Mar 06 2013, 03:13PM Print
Slava Registered Member #518 Joined: Tue Feb 13 2007, 05:20AM
I don't have a 100kV DC power supply, if anyone has it can they test out my idea for me...
The idea is simple... two metal cones separated by an inductor... you charge the bottom cone (the top once charges with it) and then discharge the bottom one through a spark gap...
Thanks!
Slava
Wed Mar 06 2013, 03:22PM
I think this is how David Schriner made his... Link2
Wed Mar 06 2013, 09:36PM
That looks like a TEM horn.
Thu Mar 07 2013, 12:53PM
You could make something similar using a UHF TV antenna, an ignition coil and a couple of feet of coax. Charge up the coax with the ignition coil, then discharge it into the antenna feedpoint using a little spark gap in series with the centre conductor.
Fri Mar 08 2013, 03:02PM
Conical Antennas
Extracted from: A BRIEF HISTORY OF UWB ANTENNAS here: Link2
Sat Mar 09 2013, 06:58PM
Interesting.
I wonder if a discone antenna would work..
Might be a bit more directional, just the thing for dispatching enemy dro.. um "models"..
Slava
Sun Mar 10 2013, 05:49PM
Proud Mary wrote ...
Conical Antennas
What is that?
Sun Mar 10 2013, 07:15PM
It's a very early - pre-Marconi - spark gap wireless transmitter (left) and receiver (right).
In the transmitter, two cones in series with inductors are excited by the passage of a spark across the gap between them. I would imagine the efficiency - the ratio of input energy to radiated energy - was very low.
The big issues with high power UWB pulse transmission are impedance matching, pulse rise-time, and transmission line and radiator flashover.
In spark gap type UWB devices, the output pulses of, for example only, a Marx impulse generator are shortened by means of a pulse forming line (very often co-axial), by magnetic compression, and 'shortening' gaps, and often a combination of these methods. Matching a PFN to a suitable UWB antenna is non-trivial, and often involves having to accept high losses. For example, a bow-tie antenna (not dissimilar to your cones) may require shorting the antenna ends to Earth by means of a high power resistor network to get anything approaching a decent match without flashover, and thereby shunting more energy to Earthy than is actually radiated!
Anyway, I hope this has set you on your way! smile
Slava
Mon Mar 11 2013, 12:42AM
Using my method, you don't need a pulse forming network... it works like a TEA laser.... you charge top and bottom cones... when you discharge the bottom through a spark gap, the top one remains charged and there is a sudden voltage difference between them, which should put out a lot of RF energy.... advanced versions can use SF6 gas to suppress arcing.. it someone can test out this approach i would appreciate it... thanks.
Mon Mar 11 2013, 11:21AM
The problem with your circuit is the inductance of the "Gnd" path. It would work better if you did it like Lodge, with a spark gap between the cones. Creating a voltage difference slowly, and then discharging it suddenly, works just fine. You charge the cones to opposite DC voltages and then discharge them to each other.
No pulse forming network is necessary. The discharge of the spark gap kicks the antenna into resonance, and it functions as its own pulse forming network, perfectly matched to itself by definition. :)
Sandia Labs actually built a device like this to test EMP hardening of military equipment. Firing was a two-stage process. The cones were charged to opposite voltages by a bipolar Marx generator, and then discharged to each other through a pressurised gas gap in the middle.
