  • Guests: 22
Colin 99 (53)
05/14 hvguy (41)
05/14 thehappyelectron (14)
05/14 Justin (2024)
Theoretical improvements for ETG?
Wed Mar 06 2013, 01:34AM
Yandersen wrote ...
-Honey, are you drunk?! You all smell like...
-Nommm, mum, I was j'ssst shootin' my eletramagun...
Well, Al foil, huh? 6.7 KJ per 1 gram of aluminum foil burned in oxigen - how about that "addition" to ETG "efficiency"?
Ethanol is 30KJ per 1g though. Methanol is slightly less and it is toxic.
If I can type I'm not drunk smile
Who wants to keep wrapping foil around the electrodes?
Just dump more power into it. Water is cheaper than ethanol, and still does the job.
Maybe I do have too much time on my hands these days, but I have to occupy myself doing something.
I'm sure you'll feel the same when you retire smile
EDIT: Sorry Yan, I missed 2spoons post. Nothing personal, but I have had a drink or three. (Use the 'Quote' button in future, it saves a lot of confusion.)
Thu Mar 07 2013, 01:14AM
Actually Ethanol is quite a good suggestion. Other fuels could also be used, presumably those with a lower flaspoint would be advantageous, although, as long as it ignites, energy per gram would be a relevant factor, along with cost, availability, etc.
Personally, I see non-conventional fuels (eg water) as more of a challenge, and therefore more fun, but when it comes to increasing efficiency, ethanol is certainly a contender.
(sorry about the above post, we all have off-days. I'll try and bear that in mind more in future)
Yanom
Thu Mar 07 2013, 01:28AM
Yanom Registered Member #4659 Joined: Sun Apr 29 2012, 06:14PM
how about adding some oxidizer in with all these fuel elements? kno3 (sold in a black bottle as Spectracide stump remover) might give it some more kick.
2Spoons
Thu Mar 07 2013, 02:05AM
Well, if you are going down that route you'd probably want to use hydroxylamine nitrate. Fuel and oxidiser in one. Unfortunately its toxic, and you'd have to make your own.
Ammonium nitrate would be a better candidate for mixing with an alcohol, it is far more soluble in methanol and ethanol compared to KNO3.
Reality is you'd be unlikely to get all the energy out of the fuel - you'd need to get the air/fuel ratio just right. Its still going to be better than water though.
Maxwell
Thu Mar 07 2013, 02:39AM
Maxwell Registered Member #8497 Joined: Tue Dec 04 2012, 06:24PM
Efficiency with chemical reactions becomes much more difficult to measure. Remember a chemical reaction is occurring. Total delta energy should remain constant regardless of input electrical charge - the input charge changes the rate of energy conversion in the chemical process.
I agree - using anything besides air plasma and water verges into the combustion propulsion category.
Yanom
Thu Mar 07 2013, 03:28AM
hmmm, got another idea. Since you were going to use water anyway...
Drugstore hydrogen peroxide. It's 97% water by volume, so you have that. The remaining 3% is h2o2, which *may* decompose to h2o and o2 in response to the power surge. If it does, it will release oxygen gas and hot steam.
Yandersen
Thu Mar 07 2013, 03:53AM
Um, you guys keep forgetting that platinum electrodes resistible to oxidation and high temperatures are hard to find and buy... rolleyes
Lets add some classification for those devices we are talking about.
As I understand, ETG (Electro-Thermal Gun) operates on the principle of heating propellant electrical way - so it is either air or smg non-combustible like water. If you use Al, ethanol or smg else, then electricity acts like an igniter only, so lets call those types EIG - Electro-Ignition Guns. Agreed?
Thu Mar 07 2013, 04:35AM
Agreed.
Spark plugs are available with various electrodes (including platinum) and electrode coatings, but I'd only recommend un-suppressed plugs. I have some tungsten (TIG electrodes) and tantalum (wire) that I might try.
2Spoons
Thu Mar 07 2013, 04:47AM
I think the correct term is electrothermal chemical gun. or ETC.
Andy
Fri Mar 15 2013, 12:07AM
This schemitc would be good for this type of thing. It uses microwave caps in parrellel and voltage/cap doubles each stage
arc thruster/railgun
1363309131 4266 FT1630 Mpd
