del
Vlad
Fri Feb 22 2013, 04:58PM
Registered Member #9711
del
Registered Member #543
Dual focus tubes employ cathodes with two filaments: one small, the other large. Each filament is positioned in its own slot. The smaller filament produces a small focal spot for fine focus work. The larger filament, which produces a broader focal spot, is employed when faster exposures (higher intensities) are required. These dual focus tubes usually have a switch at the end of the cathode arm that is used to select the desired focal spot.
