  • Guests: 20
hvguy (41)
thehappyelectron (14)
Justin (2024)
05/15 Linas (34)
05/15 Toasty (29)
05/16 kg7bz (68)
building a simple timer
Sun Feb 17 2013, 10:58PM Print
I feel I will be building a timer. Let's say it will count 120 seconds. There will be two timers, with one starting 60 seconds after the other. when it hits 120 it will switch off; when it counts to 120 again it will switch on. what is the best chip for counting? Is it a decade counter? I just need someone to point me in the right direction to save me time; I can do the rest.
Sun Feb 17 2013, 11:01PM
2 555 timer monostables?
Inducktion
Mon Feb 18 2013, 12:14AM
Yeah, probably a 555 timer plus some decade counters. Alternatively, if you need something more accurate you could go with a crystal oscillator, like this Link2
Mon Feb 18 2013, 02:41AM
a single 556....
Dr. Slack
Mon Feb 18 2013, 08:28AM
4040 and 4060 chips (ye olde 4000 series CMOS) are purpose built for that sort of thing. 4060 has an oscillator section which can use RC, crystal or ceramic resonator, followed by 12 binary stages, 4040 is just a 14 stage counter.
Data sheets Link2
But, wouldn't it be better to get a low cost uC dev board, preferrably one with an LCD display already attached, and program it. Waay cooler, and more flexible.
Mon Feb 18 2013, 05:21PM
I think a 556 based intervalometer will do what he needs.
Mon Feb 18 2013, 10:03PM
Dr. Slack wrote ...
I have some extra ATMega chips that I could easily program as a counter. I could just count from 0 to X and repeat. I could toggle the first output on X and second on X/2
