  • Guests: 33
05/14 hvguy (41)
05/14 thehappyelectron (14)
05/14 Justin (2024)
objects in motion stay in motion
staticmagnet25
Thu Jan 31 2013, 01:43AM Print
staticmagnet25 Registered Member #9928 Joined: Wed Jan 30 2013, 08:55PM
Hello everyone!
First time posting and I had a question about the effect of magnetic fields created by coils.
I have seen multi stage coilguns and my question is this:
If a projectile is already moving at say 20 fps, if it were to pass through a coil created feild would it slow down from its original speed or would it accelerate.
an example would be a nail being pushed into a coil using air pressure rather than it being stationary before launch.
Yanom
Thu Jan 31 2013, 03:16AM
Yanom Registered Member #4659 Joined: Sun Apr 29 2012, 06:14PM
Basically, powered coils attract iron to their center. So iron will always experience a force toward the center of a powered coil. The trick is to power a coil so that it sucks in the projectile (adding momentum to the projectile), then turn the coil off as the projectile reaches the center, so that the projectile will not experience "suckback" - that is, the slowing down of the projectile because it has passed the coil and now experiences a backwards force instead of a forwards one.
staticmagnet25
Thu Jan 31 2013, 04:06PM
So reguarless of the initial speed, as long as the projectile doesn't get caught in the middle of the coil and experience back force it will accelerate
Yandersen
Thu Jan 31 2013, 08:15PM
Yes. You should start from Wiki, actually.
Pre-acceleration will increase efficiency (if timing is correct, of course).
