  • Guests: 22
05/27 Daniel Davis (53)
05/29 Zonalklism (33)
05/29 Dr Hankenstein (67)
Ruskie
Wed Jan 16 2013, 02:00PM Print
Ruskie Registered Member #9290 Joined: Sat Jan 05 2013, 03:42PM
Wed Jan 16 2013, 02:36PM
I am not sure what you mean by running your tube 'in open air', as it should be run in a shielded cabinet, if it is to be run at all.
Setting that aside, a decision about mounting a tube will usually depend on its topology and the type of terminations it has, whether side window or end window, its weight , its cooling requirements, and so on.
Without seeing a picture of the tube, and its data sheet, it would be hard to give any reliable advice.
mikeselectricstuff
Wed Jan 16 2013, 03:19PM
Fibreglass PCB material is hard to beat for the combination of mechanical strength, electrical insulation and moderate heat resistance. The thicker 3.2mm material is very rigid.
Ruskie
Wed Jan 16 2013, 03:21PM
Ruskie
Wed Jan 16 2013, 03:26PM
Ash Small
Wed Jan 16 2013, 03:40PM
You could use fibre glass tape, rope, etc. You could cut some fibre glass cloth and twist it up into string if you can't get tape.You could also place a pad of fibre glass cloth under the tube as well.
EDIT: Woven rovings will be far better than chopped strand mat if you decide to use cloth.
Wed Jan 16 2013, 04:45PM
Bill, you should try to get hold of the actual datasheet from Toshiba so you can consult the anode heating and cooling curves for your tube. Dental tubes are only designed for short exposures, and the anode heat capacity might be exceeded and the anode damaged in a two minute continuous exposure even with your reduced input power.
The datasheet will also contain mounting recommendations.
Ruskie
Wed Jan 16 2013, 10:46PM
Thu Jan 17 2013, 12:31AM
Ruskie wrote ...
Proud Mary, good point, but that data will be hard to come by. Actually, I was mistaken initially as this tube is the Toshiba d-088 and not the 041. I've tried doing web searches but to no avail so far. Toshiba has a contact form to fill out for data, but I doubt I'd be able to get it that way.
That would be the normal thing to do. If they didn't make their datasheet available, no one would be able to design anything using their tubes, and they wouldn't sell any!
Ruskie
Thu Jan 17 2013, 03:48AM
