  • Guests: 27
Alexandre (32)
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
height vs diameter
Coronafix
Fri Aug 18 2006, 09:56AM Print
Does anyone know why the height vs diameter ratio in a tesla coil has an effect on the output?
ragnar
Fri Aug 18 2006, 10:03AM
IMHO:
#1) The height-diameter will, amongst other things, affect the length of wire and the inductance.
#2) For the highest Q, you want to maximise your stored energy (inductance/self capacitance) and minimise any losses (long thin wires, such as your resonator :P)
#3) As such, a coil where the HEIGHT is the same as the DIAMETER will enclose the maximum volume of flux for the shortest length of wire.
Please feel free to correct me. ^^
Fri Aug 18 2006, 11:00AM
1) It's very difficult to get sparks more than 3-4 times your secondary's height without setting the thing on fire. So the height affects maximum spark length in that way.
2) If the secondary is too skinny, you'll find it hard to couple enough power into it.
Wilson
Fri Aug 18 2006, 01:52PM
Wilson Registered Member #78 Joined: Thu Feb 09 2006, 11:27AM
It seems like 1:3 to 1:5 is the accepted rule of thumb in regards to dia:height ratio. Seeing as most people use it with great success, it shouldn't be too bad tongue
J. Aaron Holmes
Fri Aug 18 2006, 03:50PM
I'm building a new lowish-power (1-2kVA) coil and going with the 3:1 aspect ratio. My reasoning is thus:
1) Making the coil really tall when it won't be putting out enormous sparks would look funny; the coil would dwarf the output.
2) Making the coil diameter small just because it's short (i.e., in order to achive a h:d ratio > 3:1) means that, in order to keep Fres low, I'd have to either:
--- 2a) Add a bunch more (and finer) turns, thereby increasing copper losses.
--- 2b) Add a really ridiculously huge topload, thereby making it look stupid (same reason as too much height).
--- 2c) Both of the above.
3) I want Fres to be low, because this lets me substitute L for C in the primary tank, thereby decreasing peak current, and thereby decreasing spark gap losses (and perhaps making quenching easier).
...so for a small coil, I'd actually prefer a 3:1 ratio, though perhaps there are reasons why this is bad? My secondary h:d is 36":11".
Regards,
Aaron, N7OE
Coronafix
Sat Aug 19 2006, 12:21AM
thanks all.
I was under the impression that coils needed to stick quite closely to aspect ratios (not 3.67:1 for example)
I understand the coupling problems of too skinny a coil and the X/R of the coil, but I got a bit confused with people always talking
about an exact ratio. But what your saying is that as long as it's somewhere between 2 & 6 :1 it's ok. Depending of course on wire
diameter, number of turns, power input, resistance.
J. Aaron Holmes
Sat Aug 19 2006, 12:51AM
I'll admit, I still don't totally "get" the aspect ratio thing. At one point, John Couture espoused that "turns per inch" was a really important concept, because using too few turns, if tight-wound, would result in too great a voltage per turn and would thereby lead to insulation failure (e.g., of enamel). If this is correct, then it's tempting to think that one ought to simply consider the coil power, from which can be estimated the voltage and current in the secondary, then choose wire capable of handling the current, and add windings until your voltage per turn is below what the insulation can withstand.
At some point, presumably, those added windings (for a given coil diameter) just stop being useful, since they're so high above the primary that there's just no coupling way up there. Then you have to start growing outward (adding diameter) until those way-up turns start doing something for you. Perhaps this leads to the question: What is the minimum amount of coupling one ought to aim for at the top of the coil, and the maximum one ought to aim for at the bottom? There is an interesting "racing arcs" discussion on TCML right now that kind of ties into this.
Regards,
Aaron, N7OE
Terry Fritz
Sat Aug 19 2006, 04:21AM
Hi,
Same is true if it is too "tall"...
In general, you want the secondary to be "high enough" so that arcs to the primary metal is not a big issue. For bigger coils, diameter has to increase too... 3 to 5 is "good" wink
I can drive lower coupling due to lower loss primary design (MMCs and short good connections). DRSSTCs and many folks like to "push" couping harder... But avoid the racing arcs that can destroy the secondary coil dead
Cheers,
Terry
