  • Guests: 28
05/14 hvguy (41)
05/14 thehappyelectron (14)
05/14 Justin (2024)
Switching Device for Coilgun
josh1234
Sat Feb 23 2013, 03:47PM
josh1234 Registered Member #5969 Joined: Mon Jul 30 2012, 09:27PM
do you have a circuit diagram for it?
Yandersen
Sat Feb 23 2013, 07:13PM
Just the usual monkey design: cap-switch-coil, and a diode antiparallel to the cap. The difference is a few turns of wire over the coil, touched by a little cap charged to HV, and sparker as a switch.
Discharge can't be stopped, right - sparker acts just like a thyristor: once become conductive, stays conductive until current stops.
Yandersen
Sat Feb 23 2013, 07:43PM
Here is the diagram of the circuit shown in the video above:
1361648601 6944 FT147680 Spark Switch
The main cap was 60uF x 800V charged to ~770V, resistor was actually 3pc x 1MOhm in series, little cap is 0.1uF x 1000V, diode - 10A07.
Should work the same well for common 400V setups, howhether I would recommend HV applications.
I have just calculated the efficiency of my spark switch. I disconnected cap from charger, removed antiparallel diode and triggered the switch. As a result I got a pure RLC circuit. Voltage on cap inverted from +740V to -240V after the shot. Strange, I expected bidirectional conductance, but anyway, this way is even better... So I charged the cap again, but this time I touched sparker's terminals by a diode. This is equivalent to a mechanical switch with diode in series. This time I got -500V in return. I repeated experiments few times and got closely the same results.
Now, neglecting mechanical switch losses and diode Vdrop losses, I'm able to calculate how much energy was dissipated by a spark. So for initial 16.4J stored in the cap I got 5.8J dissipated by the spark switch. Well, almost a third of energy... Howhether I must mention that electrodes are covered by black crap already and made of some iron alloy - so the actual plasma discharge dissipation is just a part of those 5.8J. Anyway, I believe that if this device will be made properly, it may be a way more efficient (not as much as brand-new mechanical switch, of course, and far less efficient than SCR), but what is more important is it kinda unbreakable and have a high current capability, and I expect linear increase in losses relative to current, like in a semiconductor device (SCR), which is an expensive alternative.
Hm, made spark discharger with copper electrodes - the same efficiency. Well, that means that all those 5.8J are actually dissipated by the spark - light emission and electrodes' tips melting. Actually, copper electrodes are not that good - I can see copper "pimples" growing in a place where discharge happens. This changes the air gap gradually.
Oh, and BTW, even with 240V in cap switching works very well, so for conventional 400V setup spark switch will work fine - proved.
