  • Guests: 28
05/27 Daniel Davis (53)
05/29 Zonalklism (33)
05/29 Dr Hankenstein (67)
tea laser
OnTheWaterfront
Sat Dec 01 2012, 12:17AM Print
OnTheWaterfront Registered Member #7113 Joined: Mon Oct 08 2012, 11:31PM
Has anybody built a tea laser using MMC capacitors instead of the traditional aluminum foil and plastic homemade caps?
Polonium210
Fri Dec 28 2012, 01:41AM
Polonium210 Registered Member #3450 Joined: Sun Nov 28 2010, 05:01AM
I don't believe it will work because the foil and dielectric capacitor is needed to pre ionize the laser channel.
Pinky's Brain
Fri Dec 28 2012, 06:24PM
At atmospheric pressure you literally have a couple of ns to pump energy into the gap, MMC capacitors aren't fast enough.
The "homemade cap" in TEA lasers is designed for speed.
Shrad
Sun Dec 30 2012, 08:16PM
doorknobs work, but MMC will have enormous inductance for the use
Pinky's Brain
Sun Dec 30 2012, 10:01PM
It might lase, but with doorknobs you are still dumping almost all of your energy into the gap long after it has become completely useless.
