  • Guests: 29
Alexandre (32)
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
4hv.org :: Forums :: Attachments
Python source thread
Dr. Slack
Fri Nov 23 2012, 06:53PM Print
Module for arbitrary quantisation of numbers
]nicenum_py.txt[/file]
Dr. Slack
Mon Nov 26 2012, 08:58AM
Wrapper for PyAudio (which itself uses the common PortAudio library) to give non-blocking I/O, and both sync and async access to native Python types
rename the name_py.txt file as name.py
]audioio_py.txt[/file]
Dr. Slack
Mon Nov 26 2012, 08:59AM
Trivial multichannel oscillator class, uses for testing audioIO
rename the file name_py.txt to name.py
]tonegen_py.txt[/file]
Dr. Slack
Mon Nov 26 2012, 09:01AM
Multi-component 2 channel signal generator
rename file name_py.txt as name.py
]sig_gen_003_py.txt[/file]
