  • Guests: 30
05/11 ramses (16)
05/11 Arcstarter (31)
05/11 Zak (15)
Multistage Half-Bridge Coilgun: How to charge capacitor banks?
maruiwlt
Mon Nov 19 2012, 06:29AM Print
maruiwlt Registered Member #859 Joined: Mon Jun 25 2007, 10:23PM
Hello all, I'm working on a multistage half-bridge coilgun... I'm using the charging circuit from uzzor's site which is pretty expensive to build, so I was trying to think of a way to use only one charger to service all the capacitor banks.
I came up with the idea pictured below: My thinking is that as long as there is at least one capacitor bank connected to the bridge rectifier's output while the charger is on, the relays will not see any significant voltage across their contacts so I could pretty much use any general purpose relay. This way I can charge each bank one at a time using only one charger.
Does this sound like it would work?
1353306189 859 FT0 Idea
Jazzman56
Mon Nov 19 2012, 11:41AM
Jazzman56 Registered Member #7222 Joined: Sat Oct 13 2012, 06:04AM
Maruiwlt
(Not sure if this is true for capacitors but please correct me if i'm wrong )
If you where to charge one capacitor bank then flick the relay onto another (that is at a lower Voltage) the charged capacitors would dump part of there charge into the lower V cap bank until both balance out. i.e may burn your relay out.
maruiwlt
Mon Nov 19 2012, 07:10PM
Ahh, I forgot about that... So i would need relays that could handle whatever voltage the caps will be charged to.
What methods have other people used to charge caps for multistage cgs? They all just have their own charging circuit?
PSCG
Tue Nov 20 2012, 09:43AM
PSCG Registered Member #3792 Joined: Sun Mar 27 2011, 06:07PM
You could use the method that Another Coilgun has implemented: isolating the capacitor banks via high voltage diodes.
Link (under the "Voltage Charging-Parallel")
Parallelcharging1
maruiwlt
Tue Nov 20 2012, 10:07AM
Ahh can't believe I missed that. Definitely gonna look into that method! Thanks!
