Creative recycling
Thu Nov 08 2012, 10:14PM
Registered Member #96
Hi all. This is interesting, a way to recycle surplus or otherwise useless VFDs from old junk. It seems that a simple grid of Highlighter pen dots will fluoresce nicely when illuminated with the blue/green light from these. So make a small PCB with an HV850, bridge rectifier and a few MPSA42s with a cheap micro and a 4017 or 74HC138 as the driver. A good starting point for the micro is the 12F683 as it has lots of program memory, internal clock and up to 5 IO lines.
Code just needs to sequence the 4017 and sense it has reached *10. Output on 3 pins drives the 74HC138, which can be used to drive the grids (5V) or for a higher display pin count use a pair of 4017s.
Breadboard tested it just now, it seems to work well but need to finalise the board. Using an HV850 is a lot less current hungry than a buck circuit..
