Registered Member #6188
Hi,
Recently i was inspired to try and create something that would emulate muscle movement, a linear actuator, however, solenoids can only pull over a very short distance, so i want to design an array which interlock and overal contract to the shortest possible length without sacrificing too much pulling power.
What i plan on doing is create many solenoids with parts that connect each other, such as a metal rod on the front of each solenoid and a hole in the back, though im not sure exactly how much extra magnetism the rod will conduct or how it will shape the magnetic feild, and how it will affect the magnetic pull. Does anyone know a good design for what im trying to acheive? maximum linear contraction with minimal loss of power at a high speed, if not, how would i go about working out exactly how to get the most pull over a longer distance?
I am willing to put in the time and effort to hand build hundreds of small solenoids and cores to any design, whatever it takes.
Registered Member #89
Hi
Your solution may be a linear stepper motor
You just need to find a way to miniaturize it into a flexible fiber and bundle many of them together to emulate a muscle
I contemplated that the "stator" may be a thin flexible steel tube with teeth inside, and the "rotor" would be a toothed wire sliding inside it. It's hard to picture, but you'd also need to have two thin long coils built into each fiber to produce stepper action.
Not something that could be built at home, but you could probably build a supersized version as a demonstration!
Registered Member #162
How about solenoids with a large pulling force using pulleys to exchange force for distance ... like the pulley system on a hoist/crane but in reverse? e.g.
Thinking about it .... a stepper motor winding the pull-wire around it's shaft is probably the cheapest/easiest way to achieve controlled significant linear motion.
Its also the slowest method which is specifically why im not doing it. Ive looked at every alternative method, and solenoids beats them all in everything but power to force efficiency and precision , the latter being the main reason they arent used as much as others.
I dont think i was able to accurately explain what i am trying to acheive, so ive attached a rough sketch of an example im looking for whatever will allow the greatest pull force along with the highest possible amount of contraction, using either solenoids, electromagnets or both like ive done in my sketch. i dont know what the most effective way to go is when dealing with numerous solenoids, electromagnets can pull much harder than solenoids over a short distance, wheras solenoids work at a slightly longer distance thus the pull force is spread across that area. Im just not sure which is the best way to go, also considering space, although i could put a few solenoids together, i could build a hundred electromagnets and use them in the same space. im also not sure how effective using solenoids with interlocking cores (as in my sketch) would work.
Registered Member #3215
pneumatic is the route to go
you wont need a super duper compressor to get decent force (a small car AC one would do) plus you can put the compressor at any place you want in your device
Registered Member #72
Yes, solenoids are pretty quick, until you start stacking them in series. Instead of just accelerating the mass of a small amarture, you're accelerating the mass of several solenoids. Not only that, the more remote ones are accelerated to a higher speed, so your "mechnical impedance" is going as N squared, where you have N stacked solenoids. The maths is much the same as for multi-stage Marx and C-W high voltage generators.
For power to weight ratio, you want the big burly cousin of the stepper motor that Sulaiman mentioned, the brushless DC motor, driven by a sensored ESC, so you can operate down to zero rotational speed.
