Registered Member #30
I think you can electroplate any metal on any other. Or even on another piece of the same metal. Metals all form positive ions, and there's no chemical reaction between the plating metal and the substrate.
Registered Member #509
In theory what Steve says makes sense, but caswell plating sells various kits and lists what you can and cant plate on. It appears that stuff such as surface oxides (especially on aluminum) really interferes. Not sure about the caveats, just was looking into copper plating some aluminum at one point.
All the tests are on nikel, because I have a lot of coins out of that metal :)
First of all, just CuSO4 plates, but it's rough, not very uniform, has big grains, the solution has high resistivity/you need high voltage, 2.6v in my tests.
Adding sulfuric acid improves a lot the conductivity of the solution, and the deposition rates, but, everything else turns to crap, the adhesion is almost non-existent, and it's not uniform. The voltage needed drops to about 0.5V.
Adding Polyethylene glycol (PEG for short) (molecular weight 6000) makes a HUGE difference. The adhesion is excellent, extremely uniform, a single anode will plate both sides of the cathode, very smooth.
Instead of pure PEG I also tried a laxative (forlax 10g if you want to know) made of PEG + some other junk flavoring, unknown molecular weight. The results where similar. If you look for a laxative containg PEG ask for something with Macrogol. This is what they call PEG in medicine. This one is Macrogol 4000....so maybe it's molecular weight 4000.
In principle you can go for as high molecular weight as you can, higher is supposed to give finer grains, but I don't think you will see much of a improvement after about 4000.
Adding PEG also lowered the deposition a bit, I had to raise the voltage a little.
On top of that we can also add HCl, this will further inhibit (in combination with the PEG) the deposition, but it doesn't make a lot of difference in my case, a rather flat coin. Maybe if you plate vias.
