Registered Member #96
Anyone tried this yet?
Also, cheap solar wafer cells can be used in series to make an RX module by adding AC bypassing capacitors on each cell so the signals add rather than cancelling out.
A relevant idea is to use a surplus VCSEL from a broken laser mouse as a "Poor man's APD". This involves running it in negative bias with about 10V, limited to 1uA maximum through a high value resistor. I have yet to attempt this but the monolithic block sort can be harvested easily and the unused section hacksawed off.
Registered Member #286
A few years ago, I had did an experiment using tone modulated code over five 5mm IR leds setup downstairs and a few IR pin diodes as the reciever setup upstairs with preamp. Spectran was used to pull the signal out of the noize. There was no line of sight. The signal had to reflect off of several walls to reach it's destination. I wonder if it is possible to make a long distance contact by relying on cloud scatter...
Registered Member #902
When I was in middle school I used a simple circuit to modulate a laser beam's intensity to an audio source, and transmit the audio to my stereo on the shelf.
Maybe I should look into it again. Might give me something to do with my currently idling hands.
Registered Member #3215
if you want high bandwidth, you have to modulate the upper 40% amplitude of the optical power, with optional photodiode feedback
easiest way would be to use a simple constant current source and AC couple the output of an AGC signal amplifier to the current delivered to the laser diode
Registered Member #162
If you have a few old FM CB rigs (UK limit) you can use one for transmit (e.g. 100 Ohm in series with led with anti-parallel 1N4148 and a second 100 Ohm across the output, if I had a higher power led then just one series 47 Ohm resistor would do. . still 'playing') e.g. SFH4501
and one for receive (photo diode across 50 Ohm resistor (47R, 100R etc.)) as the Rx 'antenna' e.g. BP104
If you have a colaborator use 4x CB rig for full-duplex using a different channel for each direction
Old CB rigs are so cheap that building even a simple Rx/Tx system is more expensive!
Since at work we frequently throw away damaged magnifiers like this I use the lenses from them, not perfect but good enough.
The German military used filament lamps audio modulated by a mirror and Selenium detectors for front-line short range communications in WWII.
Registered Member #30
Good idea, but you'd probably want to add some DC bias to the LED/laser so it always operates above threshold. This can be done from a separate supply using a "bias tee".
Registered Member #543
And this one for the faint-hearted.
The transistor acts as a shunt, and wastes power, rather than letting the negative resistance of the arc get out of hand.
In either circuit, if 100% modulation is exceeded, the arc will go out, and not re-ignite without going through the whole procedure of allowing to cool down, re-igniting it and allowing it to reach its plateau performance which takes about quarter of an hour.
The polarity of the arc should be changed frequently to reduce electrode erosion. Maximum modulation frequency is about 10 kHz.
Steve, I did it that way for simplicity and it was only a quick test, the Tx is more like 'pulses' than a true sinewave but it seems to work as Tx/Rx is FM,
since this thread I'm going to revive my experimenting a bit as I now have a potential 'collaborator' within range of my 2m 5W handheld so we can co-ordinate 11m optical comms over 2m ham band .. just for a bit of 'fun' I may even 'invest' in a couple of higher power leds/laser diodes. Possibly dc reverse bias on the photodiode also to see if the reduced capacitance helps etc.
