  • Guests: 32
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
High current capable Class D amplifier
Experimentonomen
Sat Sept 15 2012, 11:42AM Print
This is a project i started last weekend after doingf class AB for some time.
This is the basic circuit of this project: Link2
And this is what it looks like in reality: Link2
This power stage can handle up to 47A continous into any load impedance, in the video its driving a 1ohm load.
Josh Campbell
Mon Sept 17 2012, 03:12AM
Josh Campbell Registered Member #5258 Joined: Sun Jun 10 2012, 10:15PM
Very nice, do you plan on cleaning this up into a usable package or was this just a learning project? What is the THD approximately? I'm asking because this is a project I've wanted to do for a while. Not sure if a class D would be right for me, quite a few possible draw backs, like power supply noise qualified by the power supply rejection ratio (PSRR) and by the power supply induced intermodulation distortion (PS-IMD). Would love to see more on this as you progress, keep us updated! :)
Experimentonomen
Mon Sept 17 2012, 04:43PM
It was mostly for fun as well as intended for subwoofer use only.
THD, IMD and that is completely totally unknown.
Experimentonomen
Thu Jan 17 2013, 08:28PM
This amplifier is now running off 2x85VDC and capable of over 1800 watts peak into a 2 ohm load(tested).
This is the schematic: Link2
A video: Link2
A pic: Link2
Thu Jan 17 2013, 09:14PM
E.TexasTesla Registered Member #4362 Joined: Sat Jan 21 2012, 03:44AM
Very nice. By the way your work bench looks alot like mine after a project. ;) I need more space.
Experimentonomen
Fri Jan 18 2013, 04:23PM
I'll see if i'll start working on building a housing for this amp this weekend.
teravolt
Fri Jan 18 2013, 07:16PM
What is the frequency of your triangle wave generator? Is it a triangle wave or is it a sawtooth and could you post a picture of it on the scope. thanks.
Experimentonomen
Fri Jan 18 2013, 08:20PM
Its approx 250kHz and i dont remember the amplitude, but a line signal from a cd player is barely enough to clip the amp.
teravolt
Sat Jan 19 2013, 03:15AM
I built the triangle wave generator for a PWM but I noticed that some choose a saw tooth or a triangle is the best one to use or does it matter? N.B.
Goodchild
Sat Jan 19 2013, 06:58AM
Your workbench is epic....
You are a credit to the engineering race and I salute you!
