  • Guests: 16
cbfull (52)
Steve Ward (39)
05/20 Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
IGBT driver problems
Pinkamena
Wed Jul 25 2012, 08:20PM Print
Pinkamena Registered Member #4237 Joined: Tue Nov 29 2011, 02:49PM
Hello!
I am having some problems with my IGBT driver, and I was hoping you people could help, as I have not been able to solve it on my own.
My IGBT driver circuit is unable to switch my IGBTs on when the voltage between the collector and emitter is above ~100V. I looked at the turn-on pulse from the IC (pin 6 & 7), and it became more and more noisy the higher Vce on the IGBTs was, and when it was above ~100V, it disappeared.
Here you can see my schematic (nevermind the wrong name on the IC). The IGBT driver IC is connected to two parallel IGBTs, that control the current for a coil (this is for a coilgun). When the electrolytic capacitor C is charged to over ~100V, the IGBTs will not turn on. They are rated for 1200V.
Datasheet for the IGBTs
Datasheet for the driver IC
1343247560 4237 FT0 Igbt Driver
1343247560 4237 FT0 P1000085
Ben Solon
Wed Jul 25 2012, 11:50PM
Did you see if the igbt gates will hold a charge at that voltage? Try them one at a time to check if one is leaky or something. Plus this won't affect the gates turning on or not, but if you parallel igbts you need a gate resistor for each gate. Just to reduce ringing and match the switching more accurately.
Pinkamena
Thu Jul 26 2012, 09:35AM
I have not tested that, no. How would I do that? Replace the coil in my circuit diagram with a high-ohm resistor and try to turn the IGBTs on without using the driver circuit?
Thu Jul 26 2012, 11:19AM
I would try connecting pin 3 directly to Vcc, possibly it could be picking some interference (not very likely but just to be sure).
Thu Jul 26 2012, 12:20PM
from what i can see from the Driver IC Datasheet, it already has a internal 100k pull up resistor.
other then that i cant see anything wrong with it and ive been sitting here and looking at that schematic for a while.
Jrz126
Thu Jul 26 2012, 12:56PM
Whats the 9V supply voltage look like? Might need to add some capacitance near by since the gates can pull a big slug of current when switched on.
Can it drive a single igbt?
Pinkamena
Thu Jul 26 2012, 02:31PM
Jrz126 wrote ...
No, removing one of the igbts did nothing. It still will not fire properly above 100V. The 9V power supply is able to deliver 1.2 amps, so it should be enough. It works for low Vce, like 40V.
I also noted now that when I discharge the cap bank through a resistor, the IGBTs can turn on at Vce higher than 100V. But when I tried this, sizzling noises came from somewhere, I think it might have been my 9V power supply. It is all so strange...
Another point of interest: When I attempt to switch the igbts, and it doesn't work, the cap voltage drops rather rapidly (couple of volts per second). I can think of two possible reasons why this is happening:
1 - Current goes from the collector, into the gate, through the igbt driver IC, and to ground.
2 - The igbts are only slightly turned on, letting a small amount of current go through.
What are your thoughts on this?
Thu Jul 26 2012, 05:23PM
2 is probably right. Measure the voltage of your 9V power supply. Also, an IGBT usually needs at least 12 volts to turn on fully.
Pinkamena
Thu Jul 26 2012, 05:34PM
Dr. Dark Current wrote ...
I see. I should probably find a way to supply the driver with 15V then, as the datasheet recommends. I am not certain how I should to this, though. Is it possible to make a voltage doubler for DC?
Thu Jul 26 2012, 06:57PM
How are you supplying your 9V?
