  • Guests: 30
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
SSTC question
Sat Aug 05 2006, 02:31PM Print
It would be possible to have , for a SSTC, only 2 IGBTs, as for a half bridge, but still full voltage on the primary (not V/2 as for halfbridge), something like this:
http://www.geocities.com/gemaria_ro/sstcex.html
It would use two primaries, oposite wounded ( a bifilar cable).
Marko
Sat Aug 05 2006, 03:17PM
I tried such a thing not so long ago. It won't behave as a normal bridge SSTC, but rather as double ended flyback SSTC and will suffer from big voltage spikes on primaries.
WIthout class E operation you probably won't be able to increase input voltage to more than some 50V or etc. for 600V igbt's (with best adjustment of pprimary turns and impedance match).
Sat Aug 05 2006, 03:31PM
Pitty...i would like to have some good results with only two IGBTs
second variant?
http://www.geocities.com/gemaria_ro/sstcex1.html
Each primary tuned with a paralleled C, which will short the unwanted primary spikes....?
Marko
Sat Aug 05 2006, 03:42PM
As I said, this topology can work very well in class E. Jus tput your resonant caps across the switch instead having them across the primaries.
For higher frequencies (>1mhz) IGBT's are bad choice because they are usually slow at turnoff.
Prolonged current tailing can cause them to suffer extreme losses (death) due to some energy from shunt cap getting discharged trough them while they are supposed to be 'off'.
Sat Aug 05 2006, 03:50PM
I dont make high frequency SSTCs (usually under 200 kHz), so it would not be a problem. Maibe at lower freq, the voltage spikes will be lower (your coils are high freq Firkragg).
Its hard to match a class E when you have no tools. Hmm...will see....
Sat Aug 05 2006, 10:53PM
Your circuit looks like a variation of the centre tapped circuit used in the Mazzilli flyback driver. (except without the resonant capacitor, so it's a bit more like the original Royer oscillator)
So I'm going to guess that the same conditions apply, and the switches see 2*Vdc plus spikes if you don't use a tuning capacitor, and roughly pi*Vdc if you do use one.
I guess what I'm saying is that the switches end up seeing twice the voltage applied to the primary, so you might as well use a half-bridge instead and double the DC bus voltage. I think the phasing of one of your primaries is wrong too.
Sat Aug 05 2006, 10:59PM
Couln't you buid it like a push-pull vttc, replacing the tubes with your igbt's? Use steves vttc faq's eqations to get a decent Q for your primary, then tune for resonance, and viola tongue
Sat Aug 05 2006, 11:03PM
It worked for Vladimiro Mazzilli (the guy who invented our "ZVS Flyback Driver") back in 2003
Marko
Sat Aug 05 2006, 11:38PM
Yeah, this variation of 'double-ended' drive can also work in ZVS by putting a cap across the primary aka. mazzili driver.
Without any caps, with that topology I had IRFP450's (500V) starting to avalanche at some 30V input. Not good..
Due to fast switching very high voltages develop across the primary and there's nothing to drain that energy out.
(vasil already owns one coil based on it).
I saw his schematic quite long ago, and it is actually interesting how it works on mains voltage with just 5W gate resistors.
I tought this could make nice little unregulated SMPS (with mini mosfet's requiring much less gate drive power than IGBT's). Only if peak voltage could be reduced to some 2x Vin sad
Sun Aug 06 2006, 06:50AM
The resistors are boiling hot after 1 min runing....
I run out of IGBTs stock. It would be nice to have only 2 IGBTs...Seems that would not work.
The primaries phasing is wrong yes.
