  • Guests: 23
Alexandre (32)
05/05 Alexandre (32)
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
Help with off-line smps
Thu Aug 03 2006, 06:33PM Print
I'm building a smps for my HV projects, and I need someone to just make sure the components I'm using will survive, it costs 2 good semi's a failure after all. cry
Its off-line, half-bridge topology and runs off 240v mains. The main switching mosfets are IRFP450s with PR1503s to bypass the internal diodes. All I'm really wondering is if the PR1503s are good enough, like voltage and current-wise. I'm not sure what kind of spikes I can expect, and if the diodes short the bridge is ruined.
So will these Link2 work for bypassing? I can post the whole schematic if my description is unclear.
Marko
Thu Aug 03 2006, 07:34PM
You have a lot more to tell.
Are you using high or low side driver, wich IC, regulation, and etc.
A schematic would also be nice...
Thu Aug 03 2006, 08:56PM
Currently I'm just trying to get an output from a smps transformer. I have two taken from a computer PSU and one from a monitor. I plan on rewinding one of them once I get the main switching circuitry in place. Its driven by a TL494 -> mini-h-bridge -> GDT -> mosfets -> xfrmr. Pretty crude, but I'm just experimenting.
Here is the GDT output as well. When switching a mosfet it slopes a little more of course, but by just 0.1µs or so.
I just want to know if its safe to plug into the wall yet. cheesey
1154638599 95 FT14056 Uzzors Waves Smps1
Thu Aug 03 2006, 09:19PM
Those diodes are only rated 200V at 1.5A. The diodes will see 350V plus any voltage transients (so maybe 400V). Also, the diode should usually be rated about the same as the FET, so a 15A diode would be better than 1.5A. The MUR1560 comes to mind as a suitable diode.
So, dont plug it in until you get new diodes!
Marko
Thu Aug 03 2006, 09:52PM
For such frequencies and power level internal diodes inside the mosfets are good for beggining.
You can bypass them altough if you want 'for insurance'.
Maybe you could lower the deadtime in order not to push everything to maximum instantly.
Take care around transformer, im. use one that was previously used with halfbridge (ATX transformer for example).
Thu Aug 03 2006, 11:01PM
Just think how much you'll learn for every two MOSFETs you trash. :P
The extra diodes shouldn't be needed. I've repaired and modded several commercial SMPSs that use MOSFET half-bridges, and they all seem to get by with the MOSFETs' own body-drain diodes.
The diodes only carry the transformer's magnetizing current, which is small with a well designed transformer. Even if you have a transformer with lots of magnetizing current, it's always an inductive current. What really stresses the diodes is capacitive current.
The SMPS circuit you chose is a fairly old and well-tried one. It should be pretty hard to blow up unless you make a gross mistake wiring it up, or get the transformer design so badly wrong that it saturates.
Thu Aug 03 2006, 11:13PM
It would have been nice if you got the formatting right for the schematic so we could actually read it (quote me to see how it was done) when we click it
1154638599 95 FT14056 Smps1 Uzzors
But other than that you shoud be fine without diodes wink I should also point out that you might need to put a schotty diode in series with the fet if you use an external diode as if the diode you are using has a higher Vdrop than the fet's it won't do anything (the schotty adds an extra .5v or so to the Vdrop of the internal diode, so the external one takes all of the current)
Thu Aug 03 2006, 11:59PM
Thanks for fixing the schematic ... .
I suggest you look again at the direction of the schottkey diode. It doesnt add a .5V drop, rather it adds whatever the reverse stand off voltage of the schottkey diode is (so 40V or whatever). The schottkey is forward biased when the MOSFET conducts, but is *reverse* biased when the current reverses and tries to go through the body diode.
I agree with the rest of the people here, your application is low enough in frequency that you can get by just fine on the internal body diode (though it is particularly slow at over 1uS recovery time!).
Fri Aug 04 2006, 11:56AM
Thanks for the advice. I took out the diodes and plugged it in, only to have the breaker trip. dead I was about to despair, but I found the bridge recticfier had shorted. I forgot to replace it after the first failure. (my avatar) Now would it be ok to just feed the smps with half-wave recticfied mains?
Fri Aug 04 2006, 06:02PM
I would not personally do that, but if you really cant wait...
