  • Guests: 16
05/14 hvguy (41)
05/14 thehappyelectron (14)
05/14 Justin (2024)
is my math right?
Yanom
Fri Jun 22 2012, 07:31PM Print
Yanom Registered Member #4659 Joined: Sun Apr 29 2012, 06:14PM
I made a simple coilgun using 50v power supply, 3x 470uF capacitors, and 11ohms of 24gauge wire. I tried doing the math for this:
By ohms law, 50v/11o is about 4.54 A of current.
.00141F capacitance
F = (A * s) / V , so, coil should be on for about. 015 sec.
Right? Are those equations right? Because it seems my coil isturned on longer than that: I'm getting suckback. Where could the discrepancy be?
Fri Jun 22 2012, 08:12PM
You might be neglecting the coil's inductance, which will probably be a large amount for your coil. It takes about 140 meters of wire, if you have 11 ohms of 24 awg. Anyway you build it, this will have a lot of turns and high inductance, probably 30 mH or more.
Try the RLC simulator page and dial in V = 50 volts, R = 11 ohms, C = 1.4 millifarads, and L = 30 mH. This will simulate what happens in your circuit. The inductance slows down the discharge time and lowers the peak current. I'm seeing a peak of 3.5 A that lasts about 50 msec.
Coilgun efficiency suffers from any resistance. This means the best coilguns are built from fewer turns of heavy wire, just one or two layers, and high peak current of hundreds or thousands of amps.
Hope this helps, Barry
Yanom
Fri Jun 22 2012, 09:32PM
ahh thanks. That's very helpful. Also, do I have to take into account the fact that (according to This chart a 24 AWG wire can only pass 3.5 A of current?
Sat Jun 23 2012, 02:48AM
Yanom wrote ...
Do I have to take into account the fact that (according to This chart a 24 AWG wire can only pass 3.5 A of current?
Not exactly. The chart represents the save average long-term safe current-carrying capacity.
You can at least double their figures for current that lasts only a very short time.
The real limiting factor for coilguns (with a current pulse of 20 msec or less) would be the "fuse" limit. That is, what amount of current for a few milliseconds will melt the wire? I don't have a chart handy for that, so do some web searches.
Cheers, Barry
Ben Solon
Sat Jun 23 2012, 03:02AM
Barry wrote ...
Yanom wrote ...
Cheers, Barry
i dont have the formulas memorized, but its just a function of the energy in the discharge and the mass of the wire. the limit is the melting point of the insulation if you want more than one go at it. i did something similar with induction heating.
edit: the specific heat of copper is .38gJ/g which means for every joule of energy asserted on one gram of copper, its temperature rises 1 degree C. an example would be 1kJ through 10g of copper wire would raise the copper 10 degrees. according to wikipedia, common temperatur classsifications for copper wire are: 105° C, 130° C, 155° C, 180° C and 220° C. find out what yours is, them calculate how hot you want it to get.
