  • Guests: 27
Alexandre (32)
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
4hv.org :: Forums :: Suggestion Box
Spell check
Omicron
Sat Feb 18 2006, 08:36PM Print
Omicron Registered Member #131 Joined: Fri Feb 10 2006, 09:25PM
It would be nice if this board had a built in spell check. For this board I had to buy a cheap eletronic one. It helps but it is slow. any one who has seen my posts know I am a very bad speller frown
Sat Feb 18 2006, 08:47PM
Use a progam like MS word, or if you dotn have that then use the open office document editor, to write your posts then copy and paste them to the post. TH board doesnt need a built in spell checker.
Omicron
Sat Feb 18 2006, 09:36PM
Thank you it works!
Simon
Sun Feb 19 2006, 12:11AM
I'm not sure because I don't use it but isn't there a Google spell checker as well?
Sun Feb 19 2006, 01:05AM
ya, just use the google toolbar spellchecker; it works great :)
Once a week or so you have to wait for about 30s for it to connect, and it can't handle more that 100 misspelled words (I have only got that error once), but otherwise than that it is perfect. It is designed for common typos, so it's suggestions are extremely accurate, and it has an autofix setting that fixes all of the ones it knows you just made a typo on :)
