  • Guests: 35
04/28 Steve Conner (46)
04/29 GODSFUSION (37)
04/29 Zajcek (37)
Double flyback driver??
1 2 3 4
FaLLoUT
Thu Aug 03 2006, 10:47AM Print
FaLLoUT Registered Member #241 Joined: Thu Feb 23 2006, 09:13PM
Guys i was searching the internet for the simplest flyback driver when i come up to
http://www.geocities.com/teslinasite/flytwinse.html site showing two flybacks driven at once with same driver... sounds pretty cool but he doesnt give any info about what sort of a driver to use frown can i use a normal driver or do i have to make it bigger maybe anyone got any ideas?
Thu Aug 03 2006, 11:09AM
It says "the rest of the schema is identical with that found on powerlabs.org." Since I know the site finding the schematic wasn't hard. Just read through this page http://www.powerlabs.org/flybackdriver.htm and you should be able to make it work.
Thu Aug 03 2006, 01:55PM
The last schema:
http://www.geocities.com/teslina/dblfpage.html
but....
with 2-3 DC flybacks in serie driven by separate Mazzilli drivers longer arcs can be obtained. Philer did it.
http://old.4hv.org/index.php?board=18;action=display;threadid=5167
FaLLoUT
Thu Aug 03 2006, 02:24PM
oh... yes yes i been on powerlabs before il do it from there... but it says "identical" apart from the two joined flyback parts is it all the same?
FaLLoUT
Thu Aug 03 2006, 02:43PM
hmmm from what philer did i can see that he used two seperate ZVS drivers... From the site i got the idea from he uses 1 single driver and uses 2 flybacks as a big single
flyback which metod should i use?
Thu Aug 03 2006, 03:29PM
Oi! Fallout: The board rules say no double posting within 48 hours.
Thu Aug 03 2006, 06:06PM
I beleive it's the same just use the gate winding for feedback and power for power. Use the schematic vasil posted though. Infact go for the ZVS Driver if you want to spend a little extra, the arcs will be much more impressive. shades
Thu Aug 03 2006, 06:12PM
It should work with a normal, unmodified, driver like that on powerlabs (I hate to refrence Sam for the 2n3055 since he had no part whatsoever in the design, but...).... I would recomend that you try winding the feedback coil arround only one of the flybacks, it should give you better stability (and let you usee flybacks that aren't exactly the same).
Thu Aug 03 2006, 07:02PM
The driver is "almost" identical. The original schema was with 2N3055 (too weak), Sam used a MJ transistor, I used KD. Just use the power transistor you have around.
But Mazzilli drivers are the best for high power output and intense arcs:
http://www.geocities.com/teslina/Rfly.html
...and a variant with separate gate source:
http://www.geocities.com/romtcb/groyer.html
Just choose......
FaLLoUT
Fri Aug 04 2006, 08:38AM
Sorry for the double post i didnt know. I will start with powerlab driver first and then do ZVS driver. I will only try first 2 then 1 feedback windings. If i use 2 2N3055 transistors in a darlington connection and use heatsing+fan cooling (because i have 2 2n3055 now) i think it should be fine.
