  • Guests: 19
Alfons (36)
Coronafix (51)
AmonRa (44)
05/09 Alfons (36)
05/09 Coronafix (51)
05/09 AmonRa (44)
** Add your Tesla coil here **
Tesladownunder
Sun Feb 05 2006, 02:01AM
Vasil Oct 1 2004
GU81M VTTC
GU81M high power pentode, with the grids G1 and G2 connected together, G3 to ground
2.1 kV @ 1 kVA MOT with level shifter (2.2 uF @ 6.3 kV cap)
primary: 14 cm diameter, matched impedances with the primary capacitor connected at the 34-th turn and the plate of the tube at the 48-th turn.
secondary: 7.5 cm/ 28 cm, 500 kHz
feedback coil: 21 turns, under the primary coil
no staccato used
spark lenght: 18 inches
More information here:
Tesladownunder
Sun Feb 05 2006, 02:05AM
Vasil Oct 1 2004
Royer SSTC
push pull, current fed, resonant converter with IGBTs (BUP314)
primary: 4+4 turns, 3.93" dia/1.18" lenght, 20.95 uF
134 nF primary cap
secondary: 14 cm dia/ 47 cm lenght with 0.125 mm wire, 3760 turns, self res = 76.2 kHz
spark lenght: 21 inches
Tesladownunder
Sun Feb 05 2006, 02:09AM
Steve Connor Oct 1 2004
Tesla-2
3.5" x 18" secondary, metal bowl topload
Fres=about 210 kHz
13 turn conical primary
12.5nF 22kV MMC cap
12,000 rpm async rotary gap
10kV DC power supply made with single MOT+ electrolytic caps and diodes
"Multi-Mini-Charging-Choke"
Spark length 40" at 400bps, 1kW
Fryingtonight2
Tesladownunder
Sun Feb 05 2006, 02:11AM
Tesla-1
Same parts as Tesla-2, except only 9.4nF tank cap, smaller topload, static gap, and 10kV 25mA NST.
Spark length 17"
Tccutoutsml
Tesladownunder
Sun Feb 05 2006, 02:13AM
Hammertone Oct 1 2004
This is the 2nd. coil that I built.
It is on permanent exhibit at the Danish Electricity Museum Link2
Torus: 600mm by 160mm, copper
Secondary: 600turns of 1mm wire, spacewound on 250mmØ, 870mmL polyethylene tubing.
Primary: 25mm wide, 0.6mm thick bronze strip. This gets warm during operation.
Cap: Maxwell 100.000V 40nF
Sparkgap: Sync. Rotary. 300BPS Equal Bangsize configuration.
Transformer: 20kV/3000VA (continous) Homewound.
More details:
Teslas
Tesladownunder
Sun Feb 05 2006, 02:15AM
Cesiumsponge Oct 1 2004
810 VTTC, Steve Ward clone I built last year with his help. It has been sitting around without much use. Specs are very similar.
Built as a tabletop unit, 12x12" PE base. Uses a new 810 RCA tube and a Freau 6x1.75" toroid unit and integrated breakout point. Still needs a staccato unit but I have gotten upwards of 16-17" streamers to a suspended metal rod before the plate starts getting red.
VTTC12
Tesladownunder
Sun Feb 05 2006, 02:17AM
JimmyH Oct 1 2004
This is my DRSSTC. 6x30" secondary, 7x36" toroid. Max spark length so far is 93".
Ummmm..... not sure what else to say..
oops, gotta fix the pic size
DRSSTC
Tesladownunder
Sun Feb 05 2006, 02:20AM
Steve Ward Oct 1 2004
My DRSSTC-2.
Standing at about 7' tall, this coil has produced over 11' point-to-point arcs from an estimated 4-5kVA at 100bps. It uses 700VDC input voltage to the h-bridge (consisting of 300A 1200V IGBTs). Secondary is 8"x48", tank cap is 360nF, toroids are 4.5"X : 26" and 38". More specs at my website: Link2
The photo is by Terry Blake at the 2004 Cheesehead Teslathon (Wisconsin). Here its running with 2 breakout points with arcs reaching 9-10' to ground. You can see me hunched over the variac, Jimmy on the ground next to it, and his Dad standing just to the right of the secondary.
Thon
Tesladownunder
Sun Feb 05 2006, 02:22AM
Here is another DRSSTC (my DRSSTC-3). Its a mini coil that i built with the very original ISSTC driver. This coil uses a half-bridge at 350VDC input. It uses only 2 MMC caps for 75nf at 4kv rating. The secondary is 4.5"x11", 30awg. Topped off with a 3"x12" toroid. It makes sparks up to 27" (pictured). Currently working on longer sparks. Uses around 300W at 100bps for average 24" sparks. More details at my site of course.
27in
Tesladownunder
Sun Feb 05 2006, 02:23AM
EastVoltResearch Oct 1 2004
Here are some pictures of my DRSSTC 1 system.
6.5" Secondary, 20" x 5" Toroid, 0.11uF Primary Capacitor
Resonant Frequency 100Hz
Maximum Arc Length with this system is 80"
Full Details can be here:
Full Electrical / Mechanical Design / Testing / Details along with DRSSTC II are documented in a 150+ page book I wrote which is available here:
DRSSTC II
"A Modern Day Solid State Tesla Coil Experiment"
Evr Drsstc1 02
