Registered Member #193
If the temperature, voltage and current are kept the same even when you alter the concentration then presumably you are altering the cell geometry which is an odd way to go about things. If you electrolyse a solution of copper sulphate with inert electrodes then the copper plates out onto the cathode and you get a solution of dilute sulphuric acid. However if you dilute the solution far enough there's just not enough copper there to carry the current. So part of it is carried by the hydrogen ions naturally present in the water. So the rate of production of copper falls and the rate of production of hydrogen rises, but the sum of the two rates (on a mole for mole basis) remains the same.
Registered Member #96
Hm, interesting.
I did wonder if an electroplating cell could be improved by using an X/Y stepper to move the anode pin or wire closer to the area to be plated in order to get an even plating.
Anyone have experience with plating indium or zinc? -A
Registered Member #190
I guess I should have asked it this way:
I have a chlorine generator. The voltage and maximum current is fixed. Is the rate of chlorine production increased if I use a higher salt concentration (within the range specified by the manufacturer)?
Registered Member #162
AFAIK electrolysis rate is proportional to current (Coulombs/second=Amps) so for a fixed voltage, higher conductivity (lower resistance) increases current. i.e. more salt = faster electrolysis - up to the current limit.
