  • Guests: 18
05/14 hvguy (41)
05/14 thehappyelectron (14)
05/14 Justin (2024)
ETRG: (hybrid) electrothermal railgun
keys
Mon Apr 30 2012, 09:36AM
keys Registered Member #4583 Joined: Tue Apr 24 2012, 04:30PM
rp181 wrote ...
Nope, the navy uses solid armatures. The projectiles are pushed in with hydraulics to maximize contact.
That erosion is from a solid projectile. I have to make it loose enough that the injector can push it in the rails, and that allows for wobble. It is not a skid mark- not there is physical erosion and aluminum deposits on the copper.
That link isn't pointing to anything! I'm guessing you mean the dimensioned drawings, those are mine. Feel free to use them!
Hmm nice, I didn't know that. Something went wrong with ctrl-c I guess, I meant the cylindrical-bore design (like this).
Anyway, will be building soon. I'll keep posted :).
Thanks!
--edit-- small stuff
Pinky's Brain
Mon Apr 30 2012, 12:08PM
What you suggest is essentially an electro hydrodynamic pump to create gas pressure (positive near the projectile, negative near the back). Not a plasma armature. Wouldn't it work better if the back was open, so you wouldn't create a vacuum there to oppose the force of the pump?
Don't know if it would really work though, depends on how much of the energy goes into just heating the gas.
Also I'd put a copper plate at the back of the projectile, so the arc stays with it ... then it would work more like a plasma armature.
