Registered Member #543
hsieh wrote ...
Today I tried to send 1mV(lowest voltage on my signal generator) amplitude modulated signal to the antenna terminal of my FRG-7.
First I set my signal generator to 1.2MHz and tune my FRG-7 to this frequency.I can hear the sound but the sound is very faint.
Then I tried to send 10.5MHz signal and tune to this signal.Now the sound is very clear.
Did this mean that I need to calibrate my receiver?
Remember that 1 mV is more than 1000 times larger than minimum sensitivity of receiver, which is 0.7 μV. Such a large signal could bleed through a whole defective stage, and so appear at the audio output.
A problem often found with old communications receivers is called 'finger trouble' or 'the man with the golden screwdriver' - bad work of previous owner, who interfere with circuit to 'improve' it, without knowing what they are doing. This can result in the position of dust cores, trimmer capacitors, and pre-set potentiometers being far from optimum position.
I would now suggest - as I suggested above - that you start whole re-alignment procedure given in manual, and tell me how the receiver performs at each stage.
Registered Member #1412
In fact, I am now not very sure how to alignment it.I read page 11 already but cannot understand every step.Especially steps that involve sweep signal generator.
The highest frequency of the signal generator in my school lab is 20MHz.
I also don't know what output voltage should I set my signal generator to.
It is possible to align receiver without sweep generator, by plotting frequency response graph on graph paper like Old Times, but you still need signal generator that can output 55 MHz.
So let us leave that problem, and try procedure number (2) on page 11 "Balanced Mixer" - to give us important information.
hsieh wrote ...
Did the manual means that connect drain of Q102 and Q103 to the antenna input and tune to 910KHz?
I did this but there seems to be no change on the S meter.I can hear s sound if I switch to CW mode.
Bad translation Japanese to English! It mean you must connect antenna input terminal to Earth.
Look at back of receiver. Connect wire between SW1, BC, and E. (SW1 mean Short Wave (antenna) 1, and BC mean Broadcast antenna (Medium Frequency) and E mean Earth which Americans call 'Ground')
Now there is no RF signal from outside! Only 910 kHz spurious signal receiver make itself!
Now set BAND to A, and MHz to 0 and do procedure with VR101 and TC105 to make this bad, unwanted signal as small as possible. Slowly adjust VR101 a small amount, and then TC105. Then a little more on VR101. Then a little more on TC105 until you find best combination of R and C to make 910 kHz as small as possible.
