  • Guests: 22
Shaun (34)
Spedy (30)
05/02 Adam Munich (30)
05/02 Alfredo Texacca (60)
05/04 Matthew T. (35)
Coil Connection spark when connect?
ljfa321
Mon Feb 27 2012, 06:36AM Print
ljfa321 Registered Member #4455 Joined: Sun Feb 26 2012, 12:49AM
Hi, here is another question.
Still using a one disposable camera and it's capacitor only.
When the capacitor done charge and I manually connect the coil to the capacitor, it make a big spark at the last connection. But only some of the coil I wined, not the others.
What does that mean when the coil do the spark?
Does that mean the wire on the coil is too short?
Or if its due to the wire's thickness?
Thanks.
Legit_bacon
Mon Feb 27 2012, 07:38AM
Legit_bacon Registered Member #4034 Joined: Thu Jul 28 2011, 10:41PM
It is because several 100's of amps are being conducted through the wire in a very short time, thus causing a small amount of it to melt where you connect it (think welding). And thus if your wire has any appreciable resistance it is going to inhibit the flow of electricity and there will be less current over more time (bad for a coil gun) and this will not produce a spark (or not as an impressive one).
ljfa321
Tue Feb 28 2012, 05:42AM
So spark = good~
Thanks!
PSCG
Tue Feb 28 2012, 01:28PM
PSCG Registered Member #3792 Joined: Sun Mar 27 2011, 06:07PM
lifa321 wrote...
So spark = good~
Well, not exactly. Sparks also mean a loss of energy that otherwise would be used to accelerate the projectile (i noticed that on the first coilguns i built). My suggestion is to invest on a thyristor switch (no sparks, better efficiency).
ljfa321
Tue Feb 28 2012, 03:43PM
PSCG wrote ...
OK, thanks, I'm only using manual connection on testing.
Are there any reason I should choose between To-3 or thyristor? Or they should perform the same?
Thanks
PSCG
Tue Feb 28 2012, 07:46PM
TO - 3 is a package type for semiconductors (that includes some thyristor products if you mean that). Otherwise, a BT151 series thyristor would be perfect for your low power demands.
ljfa321
Thu Mar 01 2012, 06:30AM
Thanks, I will double check on that
ljfa321
Fri Mar 02 2012, 08:14AM
Its a 2N6688 Transistor.
Since it will only be a really short time, this should work right?
PSCG
Fri Mar 02 2012, 12:54PM
lifa321 wrote ...
No, transistors would not work. As i see, 2N6688 can handle only 50A peak current (not specified by the manual, usually over a period of 8.3 or 10 milliseconds). So, unless the peak current is less than 50A, it will blow.
On the other hand, thyristors that can handle less continuous current than this transistor can handle peak current values of 100A or more.
