  • Guests: 29
Shaun (34)
Spedy (30)
05/01 Shaun (34)
05/01 Spedy (30)
05/02 Adam Munich (30)
ratio of spatial occupancy
rev
Sun Jul 23 2006, 03:40PM Print
rev Registered Member #112 Joined: Fri Feb 10 2006, 01:19AM
my multi meter has an option for "ratio of spatial occupancy". google is being no help for all it shows is referance to physical volume.
any help with this would be greatly enjoyed.
EDY19
Sun Jul 23 2006, 03:44PM
Could it be something like duty cycle? That would be a ratio of the "space" a waveform occupies in a cycle.
rev
Sun Jul 23 2006, 03:48PM
all the manual says is
Range 0.1%—99.9%, Accuracy ±(), Resolution 0.1%
Frequency of input signal 20Hz——18kHz
Extent of input signal ≥2.5V
Overload protection: 36V DC or AC virtual value.
i'd test your guess but it's still in the mail.
Alex
Sun Jul 23 2006, 04:20PM
Alex Geometrically Frustrated
Registered Member #6 Joined: Thu Feb 02 2006, 04:18AM
One of the google results that turned up was ac ebay auction for an LCR meter, it read "Ratio of Spatial Occupancy Duty," which seems to go with EDY19's guess.
Where was your meter made? That sounds like a very literal translation of a non-english word.
rev
Sun Jul 23 2006, 05:54PM
hong kong china :)
i got it from ebay too. prolly the same one.
the usuer manual is very literaly translated too.
examples:
Never use the instrument before replacing the back cover, or having the risk of electronic shock.
You must first take out the test leads before entering or deleting different current measuring
positions and.......
the manual
http://www.ehhs1960.org/tcrop/hd2100_series.pdf
Sun Jul 23 2006, 08:35PM
From the description, it's certainly duty cycle.
rev
Sun Jul 23 2006, 08:56PM
ok. i feal the same about it. i was hopeing some one has used a feature like that before.
i'll let you guys know all about it after i play with it.
it's on ebay under LCR.
it is an hjd2107b. only $49.95 http://szhongda.en.alibaba.com/product/50108604/50491522/Digital_Multimeters/Digital_Multimeter.html
i'll let you know how good/crappy it is when i have it in my hands.
