  • Guests: 15
Matthew T. (35)
Amrit Deshmukh (60)
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
Railgun proposal for my cap bank.
Tesladownunder
Fri Jul 21 2006, 11:30AM Print
I have a bit of a hankering to try my big cap bank on a railgun. Having seen what explosive power the discharge has, I am inclined to think a plasma armature setup might be better than a metal projectile.
The cap bank is 225uF at 12kV (=16kJ) and each of the 3 caps is 100kA rated. It has mechanical switching which has been reliable up to the highest energy I have used of 5kJ and the highest current of 80kA. The lowest voltage rated cap (12kV) is 80% reversal rated and the other caps are 20% rated at 20kV.
My previous railgun which only just got to a firing stage used 1.5kJ of electrolytics with SCR switching. It had pneumatic injection and Teflon rails. I didn't get to doing velocity measurements.
For this cap bank, however the explosive effect will be high and I don't think pneumatic injection is worthwhile in this case. The ability to contain high pressures will place a lot of stress on the insulator and the area it enters. The rails will be close and may spontaneously fire but I plan to have an alfoil ignitor to provide the initial path for the plasma behind the projectile.
Any comments?
Pic shows my previous setup.
Peter
1153481412 10 FT0 Railguncomplete1
Quantum Singularity
Sat Jul 22 2006, 02:13AM
Well, I orignally bought my big maxwells with the intentions of building a railgun. However at that time there was little info online and my prototype didnt work. We were just kinda winging it. I did succesfully launch a projectile straight up perpendicular to the rails though. dead So I cant offer much assistance but I would definately like to hear whatever results you attain if you build one. Maybe one day I'll try the railgun again but for now its going to induction launchers / shrinkers. I am currently working on a heavy duty sprak gap switch for it, once it is complete I got a whole lot of projects I want to try! Good luck.
