  • Guests: 20
a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
05/09 Coronafix (51)
Kaizer DRSSTC III
Wed Jan 27 2016, 01:06PM
Updated first post with progress of the coil and video from first light test.
Fri Apr 01 2016, 07:06PM
Updated main post with first full power light and MIDI playback, also the surprisingly low power usage.
Vale
Sat Apr 02 2016, 11:15AM
Vale Registered Member #54139 Joined: Mon Dec 29 2014, 08:19PM
Night shot would have been awesome, looks cool anyway.
Sat Apr 02 2016, 11:54AM
Vale wrote ...
Our main priority is also finding a large place indoors where we are in much better control of everything. We just wanted to get a video of sparks of atleast 3 meters and use that with a few contacts we have to show off what kind of equipment it is and see if we can find a mutual advantage of us getting housing and they can use it in education, still operated by me of course.
Only time will tell :) Other option is that my little family and I move to a house with a big work shop, which is also within a years plan or so.
Sun Sept 11 2016, 08:22PM
Updated main thread with 3 new videos, recorded after removing real-time current control from the IGBT bricks.
Uspring
Mon Sept 12 2016, 10:40AM
Mads wrote:
I have cut out the bonding wires to the RTC circuit of the CM600-24FA IGBT bricks, which we thought could be one of the reasons that we were not able to trip the 1500 A OCD setting. While it might have limited the operation a little bit, it was nowhere near hindering performance, this coil is just so high impedance that it runs long on-times instead of high peak currents.
Did you try detuning the coil somewhat? That should shift the primary current max if limited by secondary loading a bit up. I believe lowering primary res frequency by increasing primary inductance is preferable to adding primary capacitance.
Mon Sept 12 2016, 10:47AM
Uspring wrote ...
As it is tapped at exactly where javatc predicts, there certainly is room for lowering the primary frequency.
There are so many things we want to try, experiment with, measure etc, but we have had so bad luck in getting time to run it, this time we was shut down by a neighbor noise complaint after 20 minutes of testing. So we are now looking for a new place to run it and is on break until we have that :(
Uspring
Mon Sept 12 2016, 03:16PM
I met a guy showing a rather big coil at the Nottingham Gaussfest. Inside the hall it was permanently arcing to the walls and ceiling. So I asked him, how long the sparks would be if it were run outside. He told me, he doesn't know. He never had an opportunity to do this.
We should collect some money to offer a prize to the inventor of a TC muffler.
Mon Sept 12 2016, 03:32PM
Congratulations on this test run.
Try to get access to an electrical outlet in an industrial area, where neighbours is not a problem. Here at 56 degrees north, this time of the year is perfect for outside tuning, since darkness falls at 20 hours.
Better would be an old hangar, but that is hard to come by.
We need 6-7 meters to the ceiling.
Cheers, Finn Hammer
Wed Aug 16 2017, 06:27AM
18 new photos, additional construction information and complete full-bridge schematics have been added to the original article: Link2
