Registered Member #4201
Hey,
I have been doing laboratory test between sodium bicarbonate and vinegar. I realised that reacting 1M of acetic acid with solid sodium bicarbonate will not produce any pressure. In fact, the lower the concentration of acetic acid, the better it's reactivity. The lowest concentration i ventured into was 0.37M.
Could someone explain to me why the lower the concentration of acetic acid, the more reactive the reaction is? I understand it is an acid-base reaction.
Registered Member #3883
That is odd, could you elaborate on how the experiment was performed? Apparatus, state of the bicarbonate (lump/powder) etc would help.
One possibility is that the sodium acetate produced in the reaction precipitated to form a protective layer over the bicarbonate, but I thought sodium acetate was fairly soluble in water.
Hmmmm... i pounded the finely powdered sodium bicarbonate and placed it in a vessel. Sodium bicarbonate is two times in excess. Then, i poured in the acetic acid.
There are two experiments: 1. Test out pressure produced by 400ml of 0.37M acetic acid and 24g of sodium bicarbonate, Pressure produced = 18PSI 2. Test our pressure produced by 400ml of 1M acetic acid and 60g of sodium bicarbonate, Pressure produced = 0PSI
Our vessel has an space volume of 5L
Sooo, could you help explain why lower concentration of acetic acid is better? Im really confused.
Sorry, Sophie. I am at a complete loss here, I can't think of any reason why this happened. Have you repeated the experiment? Could be a mistake somewhere, did you make the solutions yourself from the same stock? The reaction should be quite vigorous, did you observe the reaction?
Registered Member #4274
If you're talking about the concentration of the Acetic acid to water, here's the problem: Acids have what is called an "Iso-corrosion Curve" which says that at higher concentrations, acids aren't active enough to really do much until they reach a certain concentration. An example of this is Sulfuric acid. Sulfuric acid can be stored in steel tanker cars at concentrations of around 100%, but drop the concentration enough (40% is around the top for H2SO4), and it will eat through that tank in no time. This may be what you are experiencing with the Acetic acid and sodium bicarbonate. We learned about this briefly in Chem 101 today.
Both experiments were conducted using the same vessel... and i didnt measure the pH.
Well,i previously described about the two experiments and the second one did not give off any pressure. Strangely, when i simply add more water to the second experiment (to prepare to throw them into waste), it immediately starts to fizz more vigorously. haha, so it kinda supports that lesser concentration is more vigorous.
On the other hand, i did more research and found out:
where if you were to scroll down to the point on "More complicated titration curves: Adding hydrochloric acid to sodium carbonate solution", they mentioned something about not giving off carbon dioxide at the initial stage.
I know they are not exactly mentioning about pressure or about acetic acid. However, there seem to be some kind of a link. Unfortunately, they did not explain much into the reasoning behind the chemical behavior.
I just wish someone could explain to me whats happening in terms of molecular level.
randommscience117 wrote ...
Does it have something to do about the dissociation of acid in water? Could you explain more in terms of molecular level?
