  • Guests: 22
Linas (34)
Toasty (29)
05/16 kg7bz (68)
05/16 steve516 (31)
05/17 Finn Hammer (72)
Reaction between sodium bicarbonate and acetic acid
Sophie Amelia
Mon Jan 09 2012, 06:08AM Print
Sophie Amelia Registered Member #4201 Joined: Wed Nov 09 2011, 07:42AM
Hey,
I have been doing laboratory test between sodium bicarbonate and vinegar. I realised that reacting 1M of acetic acid with solid sodium bicarbonate will not produce any pressure. In fact, the lower the concentration of acetic acid, the better it's reactivity. The lowest concentration i ventured into was 0.37M.
Could someone explain to me why the lower the concentration of acetic acid, the more reactive the reaction is? I understand it is an acid-base reaction.
Thanks
Fulmen
Mon Jan 09 2012, 01:13PM
Fulmen Registered Member #3883 Joined: Fri May 13 2011, 06:30PM
That is odd, could you elaborate on how the experiment was performed? Apparatus, state of the bicarbonate (lump/powder) etc would help.
One possibility is that the sodium acetate produced in the reaction precipitated to form a protective layer over the bicarbonate, but I thought sodium acetate was fairly soluble in water.
radiotech
Tue Jan 10 2012, 04:21AM
Could it have anything to do with the sodium bicarbonate buffering the acetic acid
solution at the higher molarity and using up all the H+ ?
Sophie Amelia
Tue Jan 10 2012, 06:45AM
Hmmmm... i pounded the finely powdered sodium bicarbonate and placed it in a vessel. Sodium bicarbonate is two times in excess. Then, i poured in the acetic acid.
There are two experiments:
1. Test out pressure produced by 400ml of 0.37M acetic acid and 24g of sodium bicarbonate, Pressure produced = 18PSI
2. Test our pressure produced by 400ml of 1M acetic acid and 60g of sodium bicarbonate, Pressure produced = 0PSI
Our vessel has an space volume of 5L
Sooo, could you help explain why lower concentration of acetic acid is better? Im really confused.
Fulmen
Wed Jan 11 2012, 11:11AM
Sorry, Sophie. I am at a complete loss here, I can't think of any reason why this happened. Have you repeated the experiment? Could be a mistake somewhere, did you make the solutions yourself from the same stock? The reaction should be quite vigorous, did you observe the reaction?
radiotech
Thu Jan 12 2012, 04:32AM
Have you a way of measuring the pH of both vessels?
Wastrel
Fri Jan 13 2012, 12:42PM
Wastrel Registered Member #4095 Joined: Thu Sept 15 2011, 03:19PM
Either the container was not gas tight for the second run or it had finished by the time it was sealed.
randommscience117
Fri Jan 13 2012, 11:27PM
randommscience117 Registered Member #4274 Joined: Mon Dec 19 2011, 03:10AM
If you're talking about the concentration of the Acetic acid to water, here's the problem: Acids have what is called an "Iso-corrosion Curve" which says that at higher concentrations, acids aren't active enough to really do much until they reach a certain concentration. An example of this is Sulfuric acid. Sulfuric acid can be stored in steel tanker cars at concentrations of around 100%, but drop the concentration enough (40% is around the top for H2SO4), and it will eat through that tank in no time. This may be what you are experiencing with the Acetic acid and sodium bicarbonate. We learned about this briefly in Chem 101 today.
Sophie Amelia
Sun Jan 15 2012, 08:25AM
Both experiments were conducted using the same vessel... and i didnt measure the pH.
Well,i previously described about the two experiments and the second one did not give off any pressure. Strangely, when i simply add more water to the second experiment (to prepare to throw them into waste), it immediately starts to fizz more vigorously. haha, so it kinda supports that lesser concentration is more vigorous.
On the other hand, i did more research and found out:
where if you were to scroll down to the point on "More complicated titration curves: Adding hydrochloric acid to sodium carbonate solution", they mentioned something about not giving off carbon dioxide at the initial stage.
I know they are not exactly mentioning about pressure or about acetic acid. However, there seem to be some kind of a link. Unfortunately, they did not explain much into the reasoning behind the chemical behavior.
I just wish someone could explain to me whats happening in terms of molecular level.
Thanks
Sophie Amelia
Sun Jan 15 2012, 08:29AM
randommscience117 wrote ...
Does it have something to do about the dissociation of acid in water? Could you explain more in terms of molecular level?
Thanks
