  • Guests: 24
05/11 ramses (16)
05/11 Arcstarter (31)
05/11 Zak (15)
Which type of coilgun is the most efficient?
AndrewM
Wed Dec 28 2011, 03:48PM Print
In terms of kinetic energy transfer, single stage, which type of coil gun could be considered the most efficient. I don't care about velocity, only efficiency, so if need be assume an optimal projectile for each type, even if said projectile is 20 pounds.
Reluctance?
Induction?
Disk/Pancake?
Thompson Ring?
JohnL
Thu Dec 29 2011, 02:24AM
JohnL Registered Member #3842 Joined: Thu Apr 21 2011, 12:19PM
As far as I know, disk launchers and thompson rings are just induction launchers. Fastmhz has managed to get almost 10% efficiency with pancake coil induction launchers. I haven't got more than 2.3% efficency with reluctance coilguns.
EDIT: Here's a link to fastmhz site http://fastmhz.com/?p=33
PSCG
Thu Dec 29 2011, 08:10AM
PSCG Registered Member #3792 Joined: Sun Mar 27 2011, 06:07PM
Well, at least i know that reluctance coilguns have reached 6% efficiency (not sure for other projects). Take a look.
JohnL
Thu Dec 29 2011, 12:45PM
I had a good look at the 6% efficient coilgun, and there are two technical discrepancies. One is that "initially it fired a 30mm round at 27 m/s" on 47 J energy? and the only projectile that it described is a small nail. Also when I made the coil with barry's inductor sim and used the specs for an RLC circuit I got a pulse that goes on for over a second. Some of the specs (or my interpretation of them) could be wrong, but it seems very fishy to me.
Saz43
Thu Dec 29 2011, 11:22PM
That "PAR I" looked a little fishy to me too, but reluctance coilguns can get up to 15% efficiency for hobbyist designs, probably more if you tried hard enough. The trick is to use low voltage, enhanced flux linkage, proper switching/quenching, and multiple coil stages stages.
Multistage Low Voltage Coilgun
Enhanced Flux Linkage
Diode Commutation Modification
Coilgun Systems really is the authority on coilgun research!
Fri Dec 30 2011, 08:38AM
What's the difference between a coilgun and a linear motor?
Efficiency tongue
AndrewM
Wed Jan 04 2012, 05:25PM
So if I was going to build an induction launcher (pancake, for example) with the goal of efficiency, I'd want a thick, highly conductive, projectile, no?
Turkey9
Wed Jan 04 2012, 07:48PM
You'd want one that wasn't much thicker than the skin depth at the frequency of your pulse. You want to optimize velocity as the energy increases due to it's square, so a thicker projectile wouldn't help you out.
