  • Guests: 21
05/11 ramses (16)
05/11 Arcstarter (31)
05/11 Zak (15)
Coilgun Design Spreadsheet
ben5017
Thu Dec 15 2011, 07:33PM Print
ben5017 Registered Member #3315 Joined: Thu Oct 14 2010, 04:23PM
I am working on a spreadsheet to approximate the velocity, timing and other characteristics of a coilgun. I am requesting data from some of you guys so i can see how accurate it is. If it is resionably close i will post the excell sheet on this thread.
Info I need:
projectile speed
projectile weight
estimate efficency
voltage
capatance
stages if any
switching method
Saz43
Sat Dec 17 2011, 01:39AM
You mean data from coilguns we've built?
projectile speed: 39.2m/s
projectile weight: 32.8kg
(actual) efficiency: 2.02%
voltage: 400V
capacitance: 15,600 uF
stages if any: 1
switching method: SCR, single diode commutated
Turkey9
Sat Dec 17 2011, 08:45PM
You must mean 32.8g, right?
Saz43
Sat Dec 17 2011, 09:23PM
Turkey9 wrote ...
Nope, 32.8 kg. My mistake was the efficiency, i meant 2020% cheesey
pauleddy
Sat Dec 17 2011, 11:40PM
pauleddy Registered Member #2909 Joined: Wed Jun 09 2010, 12:31AM
its more of a morter
projectile speed: 6m/s
projectile weight: 3kg
efficiency: ?
voltage: 800V
capacitance: 27,200 uF
stages if any: 1
switching method: large 3 phase, 400v 800A, soleniod fired, mains switch.
coil: primary from a Pig trasformer.
