  • Guests: 26
Colin 99 (53)
05/14 hvguy (41)
05/14 thehappyelectron (14)
05/14 Justin (2024)
Why a diode in Anti-parallel, and not series?
Inducktion
Thu Nov 10 2011, 04:03AM Print
Is there any particular reason behind it? Or is it because of the inductor = voltage needs to go somewhere thing?
Saz43
Thu Nov 10 2011, 04:14AM
Current and voltage are 90 degrees out of phase in an RLC circuit. Blocking reverse current (which the SCR already does in most designs) will not protect your capacitors- voltage goes negative during forward current, and max negative voltage occurs when current is zero.
The solution is to prevent a reverse charge from building up across the capacitor with an anti-parallel diode. You can also think of it as bypassing the capacitor after it reaches zero volts and switching to an RL circuit.
