  • Guests: 28
05/14 hvguy (41)
05/14 thehappyelectron (14)
05/14 Justin (2024)
Capacitor charger
earth3
Wed Nov 02 2011, 12:31AM Print
earth3 Registered Member #3721 Joined: Sun Feb 27 2011, 04:43AM
i have a doubt abt uzzors capacitor charger 50W. What does he mean by 1/2 LM393 in the circuit?
http://uzzors2k.4hv.org/index.php?page=capcharger2
im green in electronics so please help
Inducktion
Wed Nov 02 2011, 12:33AM
An LM393 has two comparator's inside of it. Look up the datasheet for the part and you'll understand. :)
earth3
Wed Nov 02 2011, 12:36AM
i know i sound like a noob but how do i connect it? it only got 8 pins
Inducktion
Wed Nov 02 2011, 01:49AM
Again; Look up the datasheet. the pin numbers will designate a +, -, output, Vcc, and GND or Vee.
Connect the Vcc to your supply voltage, the GND/Vee to your ground, and the + or - to however it says to connect it in the schematic.
earth3
Wed Nov 02 2011, 01:00PM
ground? huh you mean the negative?
earth3
Wed Nov 02 2011, 01:03PM
got one more doubt can i use KIA 393P instead? it almost looks like a LM393
Inducktion
Wed Nov 02 2011, 02:26PM
Yes, you can use the KIA393P. It's still technically the same thing.
And yes, GND = Negative voltage supply, if you have it.
