  • Guests: 28
Colin 99 (53)
05/14 hvguy (41)
05/14 thehappyelectron (14)
05/14 Justin (2024)
what to use as a barrel?
StridAst
Wed Nov 02 2011, 04:28PM
StridAst Registered Member #3623 Joined: Sun Jan 16 2011, 10:13PM
I use a plastic barrel from an airsoft gun in my coilgun. simple, easy and effective.
Saz43
Wed Nov 02 2011, 05:59PM
Saz43 Registered Member #1525 Joined: Mon Jun 09 2008, 12:16AM
Fraggle wrote ...
I can`t think of a good reason to have a barrel at all.
To protect the thin enamel insulation on magnet wire from abrasion by the projectile? Another Coilgun's barrelless design used wire with thick PVC insulation which protected the wire, but with the average magnet wire coils, I'd be worried about the insulation getting chipped off and the projectile causing a short.
Inducktion
Wed Nov 02 2011, 06:08PM
I still need to find something suitable.... :/
Inducktion
Sat Nov 05 2011, 03:59AM
Aha, I found a perfect piece of PVC pipe lying in my basement. It was sort of hidden away, but I'm glad I found it!
HB
Sat Nov 05 2011, 05:32AM
HB Registered Member #4146 Joined: Tue Oct 18 2011, 02:01AM
I don't know much about coilguns at all but I would expect that the barrel would have alot to do with how straight your projectile flies as well.
jnbrex
Sun Nov 06 2011, 03:45AM
jnbrex Registered Member #3950 Joined: Wed Jun 15 2011, 12:45AM
I wouldn't use a barrel. If the projectile is positioned properly (slightly inside of the coil) before firing, the magnetic field will cause the projectile to "float" exactly at the center of your coil, never touching the sides. A great way to make a perfect coil, I have found, is to wrap you projectile in one layer of normal, clear tape, and clamp it in a vise. Then, using relatively thick enameled wire (14 awg or more) wind your coil around the projectile. If you do this properly you will end up with a coil that minimizes the air gap between the projectile and the coil and is exactly the same length as your projectile. This has worked well for me, and I have gotten 4% efficiency with an un-tuned coil using this method.
Turkey9
Sun Nov 06 2011, 04:15AM
In theory barrels are not needed for single stage coilguns, but are essential for multistage ones. You can't line up all the coils and sensors if they are all individual. Any misalignment and the projectile will hit the edge of the coil damaging the wire and losing energy if it even makes it out of the gun.
Tetris
Sun Nov 06 2011, 10:41PM
Going by some of mythbusters episodes... duct tape, man. duct tape. It can be used as a cannon. I am pretty sure its a cheap substitution for an expensive barrel... and its totally awesome.
