  • Guests: 29
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
Class E SSTC thread
first  6 7 8 9
ragnar
Mon Jul 24 2006, 10:40AM
The power going through the anticoil would be disproportionate (to its size) considering the small amount of power I can currently monger with any of my drivers.
On the other hand, for extra geek points I'm raising the fres on the UOMFGSTFUHFSSTC to 12MHz and redesigning the driver starting tomorrow. When he comes to real fruition (as opposed to single-figure-wattage discharges in a lightbulb), I'll start a thread.
And yes, the name is immature, and you guys better choose something else for it. =)
Mon Jul 24 2006, 01:07PM
I was a bit busy this days so assembly of main board turned a bit slowish. :/
Here is a simplified plan of entire coil (pic = 1000 words).
Just to add, electronics are supplied from polarity inverse to input voltage due to buck/boost.
LM2575 shuts the circuit down once heatsink reaches critical temperature.
1153746460 89 FT12529 Classeplan
Tue Jul 25 2006, 01:11PM
If your regulator is giving a negative output, you're going to have trouble driving the gate of the main FET directly, since it needs a positive voltage. Put a minus sign in front of the "15V" label on your "9A Gate Driver" block and think about what's going to happen.
Tue Jul 25 2006, 05:19PM
Yeah, I see now.
Schematic is a bit wrong, since I should have put 'GND's on anywhere -15V goes, and actual GND is Vcc to chps.
-15V also goes to source of mosfet wich isn't actually shown.
Since I'm not using initial unregulated supply anywhere directly there's no actual need to correct polarity towards it.
Tue Jul 25 2006, 11:00PM
Ohh, I thought you were driving the logic off the same battery or whatever, as the drain supply to the Class-E power amp. My mistake. If you're not doing that though, why do you need the fancy buck-boost regulator at all? Can't you just use an auxiliary supply that gives more voltage?
BTW, I got this from Richie Burnett, I guess he's been reading our ponderings on what the RF chokes are for. Thanks Richie! :P
richie wrote ...
Incidentally, the reason why you should use an RFC, normally in the drain
lead of a Class-E amp is because it acts like a constant current source and
presents a high impedance to all the harmonics from the MOSFET switching.
In short, it keeps RF current out of the supply wiring. In a Class E SSTC
you could connect the TC primary in place of the RFC and it does work, but
its inductance value will be much smaller than the RFC that you would
otherwise have used to supply the drain. This means that there will be a
larger ripple current through this component acting as the drain choke, plus
the actual AC load current which flows through this inductor and the supply
wiring!
The drain choke is normally thought of as a constant supply of current
because it is sized to be large compared to the operating frequency. Since
it is large the current through the RFC doesn't change significantly during
one RF cycle. This constant current is then alternately redirected between
the MOSFET channel and the load network of the Class-E amp as the device
switches. In the interest of not quickly re-directing large currents over
large paths, it makes sense to connect the load network of the Class-E
amplifier directly across the switch. I.e. Drain-to-source across the
MOSFET. Then the choke current can alternate between the MOSFET channel and
the load network without having to take a detour around the PSU wiring and
decoupling!
I guess the practical upshot of this, is that if you decide to use your primary coil in place of the RFC, you should bring the other end of the primary coil (that isn't connected to the drain) back close to the MOSFET source terminal, and connect it to the source via the best RF bypass capacitor you can get, making sure it has short leads. Then feed in the DC power across this cap. Even so, it'll probably still barf more RF back into the power supply wires than if you did it Richie's way.
Sun Sept 10 2006, 06:28PM
Oh, thanks steve! I will be putting a large dewcoupling cap and biggest filter choke I can find on 100V bus!
I already noticed that I can draw 'arcs' from my power supply (~50V) when I disconnect the aligator clip.
RF sloshed back into power supply ignites a small arc and onised air conducts amp-tow of current while clip is few mm open!
A bit forgotten project I admit neutral But beginning of school somehow gave my will back.
Last days I have been testing the board I built, designed to fit beautifully in small box I had.
Sun Sept 17 2006, 04:06PM
The thing is fully functional finally.
Board is ready to fit into it's place..
1158509180 89 FT12529 Board 1158509180 89 FT12529 Board 1 1158509180 89 FT12529 Board 2
Driving a IRFP450 (2,5nF) at 2Mhz, gate signal 500ns 5V div. I took special care for a low inductance design and I get almost datasheet-like rise and fall times with 1 ohm gate resistor. UCC gets pretty hot with this. SMD resistor does good job keeping inductance low.. smile
1158509180 89 FT12529 Scope
Under-board.
1158509180 89 FT12529 Nn
And yeah, I didn't forget to make space for power supply..
FOr higher power levels I may add forced air cooling to small heatsink..
EDY19
Sun Sept 17 2006, 06:04PM
That looks VERY nice, firkragg! The gate waveforms are also quite impressive. Have any tests with a coil in place been done with this setup?
Tue Sept 19 2006, 10:09PM
I assembled the coil and did some preliminary tests; 2cm sparks at 12V, nothing impressive, and PLL seems to be somehow unlocky. I think I really need bigger VCO cap and a bit bigger
DC blocking cap at CT, I think it is being overloaded and CT current is very low at low input voltages.
I know spark looks awful, I have always had trouble with that. I would need to shoot in dark and focus poorly on the rest of coil :/ If I underexpose sparks look few times shorter than really.
This run is at about 20V, som 4cm sparks.
I didn't check it for class E yet but I used the same cap from before, primary and coupling are also close enough.
1158703739 89 FT12529 Coil
Tue Oct 10 2006, 09:49PM
Coil got a new secondary and fancy hovering primary; I'm currently happy with it as is.
Power supply will be added but I don't want to press with it.
1160484135 89 FT16969 P3260009 1160484135 89 FT16969 P3170021
This is how I blew my old secondary: after playng with various spark effects, vortexes and trans-dimensional portals I finally tangled a wire just in the middle of the secondary, shorting a lot of turns and setitng the thing of fire.
As he was ruin anyway I decided to make a new one, and this time without bad connections and bugs. With nicer, bigger topload it works flawlessly, somewhere above 1Mhz.
I don't aim for extreme frequencies yet as people still find large sparks more amusing than fact that coil works at 30Mhz or etc. cheesey
1160516988 89 FT12529 Newsec
first  6 7 8 9
