Registered Member #3567
I am doing reasearch in a device I plan to use in places where power is not located. Because I can't run a vacuum pump, is there any mix of chemicals that would absorb air down to around 35 micron? If this is not possible using cheap chemicals (it won't be useful to poor people if it costs 1,000) is there another way? The vacuum does not have to last, a period of maybe 5-10 minutes would be good.
I'm kindof cheeting here, if I don't get an answer, I'll have to spend hours in books instead at the telly :)
Registered Member #193
Sort of.
Also, you could flush the air out with CO2 then connect the chamber to a container of Na2O. I's not easy, but it's possible. The trouble is, if they can afford that, they can afford a diesel driven pump.
Registered Member #3414
I found a link to zeolite molecular traps, as promised:
I'm not sure if it will be usable in your application, but it does demonstrate that you can achieve a hard vacuum using chemicals.
(A similar mechanism is also used in oxygen concentrators, where zeolites that specifically absorb nitrogen are used to increase the oxygen concentration in air. These have two chambers which are used and 'flushed' alternately (usually every 22 seconds))
Zeolite traps are fine, if you have a vacuum pump to revive them and access to liquid nitrogen to cool them. I suspect those criteria will not apply in this case.
Incidentally, since about 1% of the air is argon which can not be removed chemically, the simple answer to the OP is "no".
Bored Chemist wrote ...
There was no mention of these requirements in the several threads on other forums where people have put this into practice.
While a foreline pump of some description is required, the zeolites can apparently be revived by baking.
I'll try to find those old threads (it's a couple of years since I read them)
I've not seen this mentioned elsewhere, but I assume you are correct.
That would imply that the zeolite trap (molecular sieve) would still be able to significantly increase the vacuum over and above whatever 'crude foreline pump' could be fashioned 'in the field'.
hmm....
I like the trap idea, and I think liquid nitro is around the cost of soda. I think it is good because the trap is disposible, after you bake it at 300 C, you put it in the socket, you use it for around 30 minutes, and you throw it away, right?
Nah wrote ...
The idea is that it is re-usable, you bake it, use it, bake it, use it............
