  • Guests: 9
Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
05/22 Skynet (32)
So, quick question
Dusk
Sun Aug 21 2011, 02:16AM Print
Dusk Registered Member #4064 Joined: Sun Aug 21 2011, 02:05AM
Is there a way for me to get myself a coil gun without making it myself? I'm not exactly gifted with circuitry, but would really like to have one. That's about it.
Forty
Sun Aug 21 2011, 02:54AM
a camera flash is practically a "coilgun: just add coil." they can be pretty easy to make with just a couple cameras and a coil of wire around a tube (that was my first gun.)
a camera has:
the capacitors which can easily be grouped together from more cameras
the charging circuit for low to high voltage, which can also be stuck together if they're the same for faster charging.
and the triggering, as you can use the camera's flash bulb as a triggered spark gap, which requires no extra modifications aside from sticking your coil in series with it.
so if you're interested AT ALL in electricity and magnetism, then i'd say just slap one together out of some cameras, it's a good learning experience (especially when you get shocked.)
coilguns, along with analog mini sumo robots, are what got me started in electronics in the first place. instructables.com will be a good resource.
If that's really not the response you were looking for, and really just want someone to build you one, then you've got to be more specific with your request. do you just need the circuitry? do you just want a gun that functions and is probably mounted to a board? or do you want a fancy, custom made, portable gun with a complete frame?
the first two could probably be had for a small fee +parts cost, but there's probably no way for the third. unless someone has a gun laying around that they'd sell.
I'll certainly help answer any questions should you decide to undertake the project yourself.
enjoy the text wall (i've had a few,) and welcome to 4hv!
Dusk
Sun Aug 21 2011, 03:01AM
honestly, i wanted to be lazy and get someone to build it for me, but i'll probably come off better if i understand how the things are put together before i go and screw with one someone else made, so, thanks bro!
Legit_bacon
Mon Aug 22 2011, 01:47AM
Legit_bacon Registered Member #4034 Joined: Thu Jul 28 2011, 10:41PM
look at amazing1.com
they have a wide range of electronics things, both as kits and assembled. they have a few coilguns.
Mon Aug 22 2011, 09:13AM
@Mattster i dissagree its way too overpriced in my opinion there
Dr. ISOTOP
Mon Aug 22 2011, 11:13AM
mattster_mac wrote ...
I view amazing1 the same way as I view Wicked Lasers - they make excellent, overpriced gadgets, but their marketing ethics are sketchy at best.
That being said, they do have some of the best-priced spun toroids around.
Legit_bacon
Mon Aug 22 2011, 09:26PM
Yes i completly agree with you guys, but can you think of any other place that sells premade coilguns?
Im of the opinion that building one yourself is the best way, but he is to lazy so any suggestions?
