  • Guests: 31
Matthew T. (35)
Amrit Deshmukh (60)
05/05 Alexandre (32)
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
[moved] The Theremin DRSSTC Controller . . .
Thu Jun 29 2006, 02:07AM Print
Inspired by watching an old space martian movie this past weekend, I have decided to pursue an interested project. Design a theremin device to control the output of a DRSSTC.
Stay tuned for more info. Should be a fun project!!!!
Desmogod
Thu Jun 29 2006, 02:45AM
I know when I run my SSTC that I get capacitively coupled and arc across to anything metal. Is this going to be a problem with DRSSTC's and the theremin aerial?
mind you, being able to play "Good Vibrations" on a DRSSTC might be highly amusing.
ragnar
Thu Jun 29 2006, 02:52AM
ROFLLES at the irony of 'good vibrations'...
...then again, I'm not sure I'd want to be waving my hand near metal plates in the close vicinity of a DRSSTC =D
...and there must be sooo many people here who don't know what a theremin is wink
sounds great, EVR =)
And I bet Steve is feeling left out since he posted his musical DRSSTC and started this musical trend =P hehe
Thu Jun 29 2006, 03:12AM
Not sure how the DRSSTC will affect performance or operation - i'll have to build one and test it to find out for sure . . . but at the least, i'll have a way cool musical instrument to annoy my co-workers with.
In regards to good vibrations, they actually used a Tannerin, which is a varient of the Theremin in that an actual mechanical slider is used to change frequency rather than antennas.
Michael W.
Thu Jun 29 2006, 04:39AM
Strange coincidence...I started building a simple theremin this morning....EVR Do you have a schematic you are working from?
Thu Jun 29 2006, 10:38AM
There are a few reference designs i was looking into, although i'll probably modify them to my tastes before using them. Here is one that claims 20Hz to 2000Hz operation.
http://www.oldtemecula.com/theremin/
Michael W.
Thu Jun 29 2006, 01:54PM
That link has the one that I'm making, the site includes some audio clips as well as plans for an optical psuedo-theremin. It puts out a soild square wave which can then be smoothed out into a sine wave giving a really nice rich sound...
Thu Jun 29 2006, 03:02PM
Actually, upon further research, i may try this digital theremin circuit. It provides DC outputs on the volume and pitch control and these can easily be implemented into pulsewidth and PRF control.
Of course, i have my reservations as to whether this will even work in the proximity of a DRSSTC, but only an actual experiment will tell . . .
1151593325 15 FT12267 Cir2
Thu Jun 29 2006, 09:23PM
I guess there would be serious EMI problems since the theremin works by generating and picking up small RF currents at frequencies not too far off where a Tesla coil works. All the more reason to use what a previous poster called an "Optical Pseudo-Theremin". tongue
Thu Jun 29 2006, 09:41PM
Even if you put yourself and theremin into faraday cage you'l still have lots of interference coupling trough cables. Best try would be powering the thing from a battery and using optical link, then caging yourself.
Without a cage coil would make an enormous 'microphony' (sort of) effect on the antennas, you may fry input HC14 chips.
When you approach it it gets even worse, since body acts as huge capacitance to the coil and just throws more of coil's electric field to the antenna, with unpredictible results.
EMI interference is actually a lesser problem, mostly it's radio frequency noise generated by sparks also helping such a circuit to go nuts.
I don't know if it is predictible to tell what will happe, depending on the reaction of the circuit, I guess it will enter an sort of 'microphony' with the coil and blow the fuse (or even worse IGBT's) with high break rate.
