Registered Member #2390
Thanks for any help in advance! I could use a little bit of help with an issue that i am having and if anyone has any ideas they would be greatly appreciated. Heres the deal! I am running a large tesla coil inside of a faraday cage. There are a few sensors inside the cage that monitor conditions of the machine under test. These run outside the cage into an electrical panel where they are then hooked up to the inputs on my plc (micrologix by allen bradley). On rare occasion, high voltage makes its way through these sensor leads, in turn, blowing the input on the card. I have tried numerous solutions and none have worked. I have tried to crowbar the sensor lead at a terminal before the input card. Using fuses, totally doesn't work because its high voltage and ultra low current. One other consideration is space! The panel housing the plc is nearly full and crowbaring every one of the 16 channel input cards would take up half of the panel space!! (5 16 ch cards)
Does anyone have any ideas that could short the sensor lead to ground before the card? Or just plain block the over voltage condition period!!?? Any help would be greatly appreciated. I need the answer to be something small that would be reliable. Say a small circuit board with all the sensor leads tied to it and back to the card. I just can't seem to figure it out! The inputs are 24vdc and 120vac. The crowbar circuit i came up with had a .1uf cap, a 520ohm resistor and a zener diode. It worked for about a thousandth of a second.
(waiting for the geniuses to make me feel more dumber...)
I did try those! I actually used the same ones that i use in my drsstc. They don't seem to be fast enough and the input blows as if they weren't even in there. I did run a test circuit that worked but it is not practical because of the added space, heres what i did. Same crowbar circuit as before but instead of running the crowbar to ground i ran it to a circuit breaker (line side) with the load side to ground. With a normally closed aux contact on the breaker carrying the input to the card. IE, crowbar kicks in, breaker trips, input to the card is broken until the breaker is reset. One problem though is that i cannot predict the amperage at the breaker accurately. It is not always the same. The hv coming through is 20 to 30kv. Low amperage but it seems a 100ma breaker catches it most of the time. (Pulls more hair out)
about 12 inputs left on the $900.00 card! I wince at every dead led!
The dc cards are 1762-iq16 and the ac cards are 1762-ia8 but the ac cards are much less prone to frying for some reason. Right now i am using a micrologix 1400 processor. Onboard in and out are internal to the control panel and the expansion cards are the ones running in and out of the cage. Another idea i had was to try and filter out the freq from the hv, another epic fail if i must say.
Well if anyone was interested, i found a solution. The answer was to build the crowbar circuits with a one way tvs in place of the 2n5XXX diode that was in the original circuit. Testing resulted in the plc inputs and its outputs being safe at up to 60kv feedback through the wiring into the test cage. My guess is that the other components in the circuit kept the diode from being smoked. On its own the tvs could not hold up to 20kv. This new circuit works on 120vac in and out, also 24vdc in and out. Hurray!!!!!! Maybe i should patent it!!!!
